3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Pussy Willow Lamp
  • last photo ←
I saw this Lamp that was made out of wooden sticks and mini light bulbs and thought, I can make that, and make it cheaper and better.  The cost of the one in the store was over $200 dollars.  So I took some pictures of it and got some ideas.
Overall, it is inexpensive (around $35 dollars) and easy to make, just a little time consuming.  Also, the one in the store was made with small incadecent lights and I wanted to make it a little brighter and energy efficient, so I made it with LEDs instead.
If you have any questions, or if something is not quite clear enough please let me know and I will assist you the best I can!
Step 1Parts and Tools Needed
  • last photo ←
Here is a list of parts and where to get them:
Black Bamboo Bundle - 1 bundle (10 sticks--you can use whatever kind of sticks that you want)
     -Bought at Micheals, $9.99
Dark Brown Floral Stem Wrap Tape - 1 roll
     -Bought at Micheals, $1.99
Pure White LED's - 25 LEDs
     -Bought off of E-bay in a bulk purchase of 500
470 Ohm 1/4 watt Resistors - 25 Resistors
     -Came free with the LED's from E-bay
12 Volt Power Supply - 1   (just what I had, so if you use a different volltage then just adjust your Resistors appropriately)
     -Left overs from a earlier project
Roll of Floral wire - 1 roll
     -Bought from Micheals, $1.49
Hot Glue Sticks - 5 sticks
     -Bought from Micheals,  $1.99
Wire Red - Roll
     -Bought at Fry's Electronics, $3.99 roll (carried at any store with electronic parts)
Wire Black - Roll
Shrink wrap
     -Bought at Fry's Electronics, $.99 (carried at any store with electronic parts)
Tools Needed:
*Wire cutters
*Soldering Iron
*Lighter (for the shrink wrap)
*Hot glue gun
*Helping Hand
(nice but not necessary)
45 comments
1-40 of 45next »
Dec 13, 2011. 11:18 AMlineofbirds says:
Wonderful project can't wait to do this!
Jul 13, 2011. 12:25 PMtony112 says:
using the "HOT GLUE" gun doesn't hurt the LED??.... I would have though, that the glue would have damaged the chip inside the LED.. any problems of it burning out later?... please advise. thanks!
Feb 28, 2011. 1:19 AMPsychotics says:
I started building this project and picked up the same Micheal's floral tape you did. The tape is so sticky it leaves thick residue over my finger tips, and I can't lay the branches down for even a second as I'm afraid it'll pick up debris. Was your tape this sticky too?
Jan 11, 2011. 3:24 PMPolilla says:
I saw a similar lamp at a restaurant, I loved it and I wanted one. Now I can do it :) Thanks for sharing.
Jan 3, 2011. 10:11 AMzthralls says:
Thanks for the inspiration! check out my take on it.
thanks
Dec 21, 2010. 11:14 AMchawla_mohali says:
super like!
Nov 10, 2010. 4:34 PMPlatt3r says:
Hey, this Instructable is awesome. I'm gonna start gathering parts, but what size LED's are you using?
Nov 15, 2010. 6:25 PMPlatt3r says:
Hey, so for a different project I tried putting hot glue on my LEDs and when I connected them to a circuit they all broke. The only thing I can think that would cause that is the heat messing up the LED innards. Was that an issue for you?
Nov 23, 2010. 5:54 AMvez87 says:
Are you sure you used the correct power supply and resistors? As too much voltage will fry an led indefinately. The Hot glue shouldn'd affect it as the innards are coated in the hard plastic that makes the diode.
Nov 23, 2010. 6:18 AMPlatt3r says:
I actually didn't use resistors, but only had a 3V power source. LED's that weren't hot glued worked and still work fine, but the hot glues ones are all fried. Hrm.....
Oct 18, 2010. 3:28 PMdeuce44 says:
Really cool! Do you think this is feasible to do on a custom xmas tree?
Oct 12, 2010. 8:55 PMThe House says:
I am absolutely going to do this when I get a chance. It is sooo cool. Great job! Vote the ef up!
Oct 12, 2010. 7:22 AMjnifrwebb says:
This looks beautiful. I am going to give it a try, but I may try to use some Christmas lights instead. I'm not sure it will look as nice as your's though.
Oct 9, 2010. 11:12 PMvishalapr says:
good
Oct 5, 2010. 4:56 PMsidthesquid says:
This is beautiful. Will work great indoors or out & in any season. I think I have to have it! Very creative.
Oct 3, 2010. 1:54 PMCriket says:
(removed by author or community request)
Oct 3, 2010. 5:01 AMnarckycypycu says:
nice work m8...bravoo :-bd
Sep 26, 2010. 3:44 PMdmb321 says:
I saw something like it in colorado and it was about 100$ thank you for the how to!
Sep 27, 2010. 7:43 PMjtmjr says:
nice i really like how this looks got my vote
I built that cake next to yours keep me in mind when u vote :)
Sep 24, 2010. 7:04 AMjeff-o says:
Actually, I rather like the "temporary" vase you used. I'd keep it as-is.
Sep 18, 2010. 4:26 PMlainey24 says:
Hi, I love this design. I have an LED question for you, though. We would like to replace our CFL bulbs because of the mercury content. We are wondering if one can purchase 9W LED bulbs that actually fit into regular lamps?
Sep 24, 2010. 7:05 AMjeff-o says:
You sure can. Check out the selection at Dealextreme. Much less expensive there, than at a local store.
Sep 18, 2010. 10:52 PMElectronics Blurred says:
Usually at the end of each CFL's life , the mercury is collected as sputter at either end of the bulb , along with the burnt phosphor .
It's not alot , really .
Not enough to really kill anyone .
Sep 18, 2010. 8:33 PMybunnygurl says:
Phillips makes the only good LED socket lamps at the moment, and while they don't have mercury they do have lead and are prone to over heating. A side note the mercury in your CFL's is less then whats in most thermostats; the most eco-friendly thing you could do is just hold on till your CFL's burn out and then replace them with LEDs. And DO NOT toss your CFL's in the trash, check with your local waste management for how to depose of house hold hazardous waste and let them deal with the recycling that needs to take place.
also awesome project... must do this one of these days.
Sep 22, 2010. 3:57 PMt4tawah says:
WOW YOUR SOOOOO TALENTED WISH YOU WERE MY BROTHER!!! OHHH YOU ARE!!!! WHEN DO I GET ONE!!!
Sep 20, 2010. 9:11 PMannieboyer99 says:
Greatest house warming gift EVER!!!
By the way:
Give me a ringle if you are single.
If we mingle, I'll make you tingle.
I'll give you two thumbs up and a fingle,
If you really are single.
Sep 20, 2010. 4:54 PMe46socal says:
Cool project. How long did it take to make? Lola_girl your coming on a little strong. You want to play hard to get a little.
Sep 20, 2010. 4:49 PMrcisneros says:
Damn. Now I have another project. :)
Nice job.
Sep 20, 2010. 12:47 PMLola_Girl says:
I really like this idea! It's very well thought out! Great job!
PS- you look really hot, too =) If you're single, give me a ringle!
Sep 20, 2010. 9:49 AMscoochmaroo says:
Want.
I'll take 10 for my wedding in June, yes?
Thanks.
Sep 19, 2010. 8:36 AMpineywoodsdavid says:
Wow I like the hot melt blob idea. That's so cool.
1-40 of 45next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
83
Author:seligtobiason(www.SeligTobiason.com)
Well, I feel like I am a pretty regular guy... I work in the Entertainment industry, right now am working for Lucas Animation on a Top secret assignment ;). I love to create things, and build things ...
more »
