loading
Step 5: Taping Up the Branches
Taping up the branches is one of the more rewarding parts because you are seeing what the final product is going to look like.
Tape the LED's in place temperarly with electrical tape. You can let the wires just hang there.  Now grab your Floral Stem Tape, start wrapping it around the branch at the base of the LED's where the shrink wrap is.  Make sure that it is nice and tight, then start wrapping the whole branch covering the wires completely (you don't want to see any red or black wires peaking out, not really something you see in nature!).  Wrap each branch coming off of the main branch, then start wrapping the main branch from the top all the way down. If there are any parts that need more tape just cut some off the roll and wrap right ontop to cover any mistakes or big bumps you want to make disapear!
<p>Gorgeous! I'm doing a version of this and I have a question. I have lamp wire laying around, and since I only wanted to use one LED I wanted to know, is one LED and one resistor wrapped to the lamp wire a thing/ would it work?</p>
Beautifully done. I imagine that you realy don't need branches though, since you are just covering them up anyway. Maybe soder up some scrape copper, or the like, to look like a tree branch. Allthough branches would be a lot easer to work with. I have flower pedel molds, I think i'll try putting LEDs in them and see how they look. I know it's been a couple of years since you post this instructable, However thank you you doing so.
Wonderful project can't wait to do this!
using the &quot;HOT GLUE&quot; gun doesn't hurt the LED??.... I would have though, that the glue would have damaged the chip inside the LED.. any problems of it burning out later?... please advise. thanks!
I have used this technique many times and have not had any problems. The LED's themselves really don't produce heat, so the glue is not keeping the LEDs or the chips hot. So really it is just glue on plastic with some light shinning through. I am sure it would be an issue with some of the 3W+ LEDs, but haven't had any problems with these lower powered LEDs.
I started building this project and picked up the same Micheal's floral tape you did. The tape is so sticky it leaves thick residue over my finger tips, and I can't lay the branches down for even a second as I'm afraid it'll pick up debris. Was your tape this sticky too?
The tape is really sticky, and I would be careful not to set them down on anything hairy. But by the time I was done wrapping the branches and working with them I had touched the branches so much I think the oils from my hands took down the stickiness. I am not sure if that was exactly it, but the tape seemed to lose the stickiness on the out side, but never lost it on the inside.<br><br>I would just be careful where you set the branches down until you have it all put together, hope that helps!
I saw a similar lamp at a restaurant, I loved it and I wanted one. Now I can do it :) Thanks for sharing.
Thanks for the inspiration! check out my take on it.<br>thanks
That looks great! Nice job, I am glad that this instructable inspired you, and thank you for sharing your picture.
super like!
Hey, this Instructable is awesome. I'm gonna start gathering parts, but what size LED's are you using?
I used 5mm LED's, but you really can use any size, it all depends on how big you want the blossoms. Let me know if you need anymore help!
Hey, so for a different project I tried putting hot glue on my LEDs and when I connected them to a circuit they all broke. The only thing I can think that would cause that is the heat messing up the LED innards. Was that an issue for you?
Are you sure you used the correct power supply and resistors? As too much voltage will fry an led indefinately. The Hot glue shouldn'd affect it as the innards are coated in the hard plastic that makes the diode.
I actually didn't use resistors, but only had a 3V power source. LED's that weren't hot glued worked and still work fine, but the hot glues ones are all fried. Hrm.....
Really cool! Do you think this is feasible to do on a custom xmas tree?
Absolutely, it was just take some serious time to do that, but it would be an amazing final product! If you end up making it please let me know how it worked out, and post some pictures too!! Good luck!
I am absolutely going to do this when I get a chance. It is sooo cool. Great job! Vote the ef up!
This looks beautiful. I am going to give it a try, but I may try to use some Christmas lights instead. I'm not sure it will look as nice as your's though.
good
This is beautiful. Will work great indoors or out &amp; in any season. I think I have to have it! Very creative.
nice work m8...bravoo :-bd
I saw something like it in colorado and it was about 100$ thank you for the how to!
Your welcome, and good luck making it!
nice i really like how this looks got my vote <br>I built that cake next to yours keep me in mind when u vote :)
Thank you, it adds a nice glow to the room! I do like your cake too, very clever idea! I appreciate your vote and I will vote for yours also, good luck!
Actually, I rather like the &quot;temporary&quot; vase you used. I'd keep it as-is.
Thanks! Yeah it is growing on me, it makes it have a little more beachy feel.
Hi, I love this design. I have an LED question for you, though. We would like to replace our CFL bulbs because of the mercury content. We are wondering if one can purchase 9W LED bulbs that actually fit into regular lamps?
You sure can. Check out the <a href="http://redirectingat.com/?id=487X782&xs=1&url=http%3A%2F%2Fwww.dealextreme.com%2Fsearch.dx%2Fsearch.E27%2520LED&sref=http%3A%2F%2Fwww.instructables.com%2Fid%2FWoodpunk-LED-Desk-Lamp%2Fstep2%2FMaterials-and-Tools%2F">selection at Dealextreme</a>. Much less expensive there, than at a local store.
Usually at the end of each CFL's life , the mercury is collected as sputter at either end of the bulb , along with the burnt phosphor .<br>It's not alot , really .<br>Not enough to really kill anyone .
Phillips makes the only good LED socket lamps at the moment, and while they don't have mercury they do have lead and are prone to over heating. A side note the mercury in your CFL's is less then whats in most thermostats; the most eco-friendly thing you could do is just hold on till your CFL's burn out and then replace them with LEDs. And DO NOT toss your CFL's in the trash, check with your local waste management for how to depose of house hold hazardous waste and let them deal with the recycling that needs to take place.<br><br>also awesome project... must do this one of these days.
WOW YOUR SOOOOO TALENTED WISH YOU WERE MY BROTHER!!! OHHH YOU ARE!!!! WHEN DO I GET ONE!!!
Greatest house warming gift EVER!!! <br>By the way: <br> <br>Give me a ringle if you are single. <br>If we mingle, I'll make you tingle. <br>I'll give you two thumbs up and a fingle, <br>If you really are single.
Cool project. How long did it take to make? Lola_girl your coming on a little strong. You want to play hard to get a little.
Damn. Now I have another project. :)<br>Nice job.
I really like this idea! It's very well thought out! Great job! <br>PS- you look really hot, too =) If you're single, give me a ringle!
Want.<br />I'll take 10 for my wedding in June, yes? <br />Thanks.
Wow I like the hot melt blob idea. That's so cool.
Love this!! <br>
This is really cool. <br>Where I live in New England we come across a lot of mountain laurels in the woods where we take our dog. I've always wanted to do something with some of the dead branches I find as they have an awesome shape. I may give this a try. <br>Thanks for sharing this and congratulations on a job well done.
Well Thank you, and you should try it out, if you need any help let me know. Good Luck!
I love it!
this is really cool!
About This Instructable
32,080views
359favorites
License:
Bio: Well, I feel like I am a pretty regular guy... I work in the Entertainment industry, right now am working for Lucas Animation on a ... More »
More by seligtobiason:TV Backlight -usb powered- Make a Robotty! LED Fan/Party Light
Add instructable to:
