Step 5Add Resistors and Power Rails
Take some 18 AWG copper wire and being to solder it in place along the sides of the LEDs. Leave approximately 4 inches of extra wire on each end to work with at the end. Assuming you are starting with the positive rail, hold the copper wire against the LED's lead just slightly above the flattened area. This flattened area is a small "warning" that soldering below it can damage the LED, so try and stay above it. Now that the copper is held against this spot, fold the lead over the copper wire and solder. If you are bulding the 87 LED model, repeat this process 29 times until all of the LED triplets have a tie to the power rail. Then repeat this process for the resistors. The resistors do not have a "safety mark", so try and remain at least 1/4 inch away from the resistor when soldering. You will notice a 10 degree angle on the LEDs in this cross-section. This would be an ideal design that could make the lamp usable without a diffuser. However, this angle is not a requirement. It is difficult to drill accurate angles in the plexi-glass. In the bulbs that were built, the angle was omitted and the holes were simply drilled straight through.
comment
Add Comment
Add Comment
