Step 7Build the Current Regulator and Bi-Pin Connectors
iImage Information
Build a current regulator as per the schematic shown below. You can design PCB artwork or build it on some proto-board. The LED mounting plate should now be populated with LEDs, resistors and power rails. Slide the mounting plate with all of its components into the clear tube protector. There are three terminals on the current regulator: (+), (-) and a tap. Connect the loose ends of one side of the power rails to the (+) and (-) holes on the PCB ensuring that the polarity is correct. Take a short piece of wire of any gauge and connect it to the first LED triplet between the resistor and the (-) side of the LED. Connect the other end of this wire to the tap on the PCB for the current regulator. This is the "tap" used to regulate current. The next step is to take a short piece of 18 AWG wire and connect the positive bi-pin connector to the input trace. Take the negative bi-pin connector and connect it to the negative power rail on the opposite end of the tube. This is the rail with the resistors installed. Trim all wires to be as short as possible. The final step in creating the LED lamp is to slide everything into the tube and slip the bi-pin connectors into the ends. Ensure that they are aligned with each other.
It is not a requirement to use bi-pin connectors. You could easily wire up a simple DC socket. to the + and negative of the circuit.
(A new, clearer schematic is coming soon.)
