3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Replacement of Baggage ligth under the seat of my scooter
Replacement of broken lamp with 2 White leds.
Step 1Remove the old Lamp
Remove the old Lamp
Make 2 holes on the lamp plastic cover for the leds, solder the 2 negative of the leds on the negative of the lamp pakage and solder the 2 positive of the leds on a resistor, solder the resistor on the positive of the lamp pakage.
5 comments
Dec 7, 2007. 11:26 PMYerboogieman says:
what voltage are the LED's?
Sep 23, 2010. 9:45 AMwobbler says:
The LED voltage won't really matter. As ComradeLynx says, they are usually about 3.00-3.3v, but any will do. The reason for it not mattering is because they are being driven from a relatively high voltage (12v) through a current limiting resistor, so although the different LED voltages will vary the current, it won't really be by much. Whatever the voltage, they will effectively take pretty much the same current, the brightness will be more of a function of how good/efficient the particular LEds are than their voltage. Nice instructible and a good idea!
Sep 18, 2008. 6:19 AMComradeLynx says:
White's usually around 3.0-3.3 volts DC
Jan 4, 2007. 6:43 AMdymo says:
YEHAAAAAAA!!!!! La tua idea SPAKKA proprio!!!! porco due.... sei un ganzo!!!!
Jan 4, 2007. 6:18 AMX9250 says:
Ciao Atomant!!!! E' bellissimo, avevo proprio idea di fare una cosa del genere, ma non sapevo da dove cominciare!!! Ora ho un mentore, lo farà subito e ti farò sapere.... Sento gia di amarti....
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:AtomAnt
