LED Ring Lamp (3D Printed + Wood Veneer + LED Strip)
Introduction: LED Ring Lamp (3D Printed + Wood Veneer + LED Strip)
This is an easy build that results in a cool little LED Ring Lamp. This light can be placed in various locations to add some color and style. No specialized tools are required and a 3D printer is not required - you can utilize a print service such as 3DHubs.com to obtain the 3D printed parts from a local printer.
Step 1: What You Will Need
3D Printed Ring
3D Printed Base
White Spray Paint
Clear Coat
Walnut Wood Veneer
Linseed Oil
Sanding Paper
RGB LED Light Strip
Clothes Iron
Orbital Sander (optional)
**Links included are affiliate links and may provide a small commission if purchased.
Step 2: 3D Printed Parts
If you are sourcing your 3D printed parts, I’d suggest a local printer on 3D Hubs so you can pick up your printed pieces without having to risk shipping. These are my recommended print settings:
Ring and Base (decent surface quality to limit amount of sanding needed)
Filament choice not really important
0.2mm layer height
15-20% infill
Orientation - laying on side
Support needed, brim recommended
Order a 3D Print
Step 3: Finishing Ring and Base
Remove support material and brim.
Sand all the printed parts to the desired smoothness. Start with 120 grit and move up to 320 grit for a nicely smooth part without visible print lines.
Wipe the sanded parts with a lightly damp cloth or paper towel.
Once the parts are dry, evenly apply primer.
Once the primer has dried, sand lightly. Wipe the sanded parts with a lightly damp cloth or paper towel.
Paint parts with the desired color. For this build, a matte white was used. Two coats are recommended.
After the paint has had enough time to dry, apply clear coat.
Step 4: Wood Veneer
Wrap wood veneer around Ring to get an estimated length, then cut slightly longer than needed.
Before using Clothes Iron remove any water and allow clothes iron to dry.
Heat up a clothes iron on the cotton setting. (Warning - some residue from the process may get on heat plate, though this did not happen during my build)
Wrap wood veneer around Ring and do not allow it to get loose as you move around the ring.
Use iron to melt adhesive, allowing it to stick to the 3D printed ring. The general speed to avoid scorching wood is 2 inches per second but it seems to be quite tolerant of the heat. Do this until all veneer is glued onto ring.
Once at end, you can trim up the excess and finally adhere the last section of the veneer.
Apply generous amount of linseed oil to veneer all the way around.
Let oil sit and penetrate wood for roughly 10-15 minutes.
Wipe any excess oil from veneer.
Step 5: Assembly
Glue the 3D printed base to the Ring and make sure the holes line up.
Insert the LED strip into the ring to get a general estimate of the length needed. First, test the length and connect the connector to confirm before cutting. Cut at the closest “cut point” on the strip (this is indicated on the strip itself). ***Be sure to cut slightly longer than the inner diameter as part of the strip will be inside the base.
Feed the LED strip into the base and connect to the power connector.
Remove backing of LED strip to expose the adhesive backing. Do this as you progress.
Adhere LED strip to the inside of the Ring.
Route the wire out the back of the base.
Connect the power connector to the wall and enjoy your new LED Ring Lamp!
Step 6: Wrap Up
Thanks for checking out the LED Ring Lamp build! If you enjoyed it, I post monthly builds using 3D printing on my website, https://www.adylinn.com/builds/.
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    What are the dimensions of the ring ?
    A little short of 8 inches in diameter. Roughly an inch thick.
    Okayy thanks alot ! ^^
    Yes, great suggestion. These look to be about standard dimensions and should fit just fine and agree would yield some really cool effects.
    I did some more search and found the SK6812 similar to the WS2812/2813 with an extra white led. It may be more efficient in term of energy consumption.
    Excellent Work. I really like the attention to detail. Are selling these ? I would like to buy one .
