3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Rollie
LED Rollie
The LED Rollie is a pretty silly, but funny thing.
Simply roll it through your neighbourhood and you'll gain a lot of attention.
I got the idea of the LED rollie when I was bored, and I saw this roll of solder, but without solder. I found out, that 2 AAA batteries fitted perfectly into the center of the roll.
Step 1Parts you'll need
Parts you\
To make one LED Rollie you'll need:
a Roll of solder, with no more solder on it.
Some LEDs (I used 2 5mm diffuse blue LEDs and 2 5mm diffuse green LEDs)
2 AAA batteries.
Some hookup wire.
an on/off switch (optional)
86 comments
1-40 of 86next »
Oct 10, 2011. 12:01 AMsbrookes1 says:
Kinda ironic how it's made from a solder spool
Oct 25, 2010. 4:58 PMagis68 says:
nice and cool my cats will love it!!!
Aug 5, 2009. 3:32 PMjam BD says:
really shouldn't solder on the batteries...
BUT...
hey the more dangerous it is the better = )
Aug 9, 2009. 9:52 PMjam BD says:
there are more dangerours tyhings to do than that
LOL =D
Sep 14, 2008. 11:59 AMdragonis says:
What can you use to substitute the roll of solder?
Jun 18, 2009. 4:30 AMBraisedDuck says:
bandage tape or cloth tape without any more tape can be a good substitute.
May 26, 2009. 6:29 AMBraisedDuck says:
what happens when the batteries die off?
Jun 18, 2009. 4:28 AMBraisedDuck says:
you can desolder???
Feb 16, 2009. 1:19 PMdudejetfighter says:
LED Yo-Yo hmmmm
Nov 28, 2008. 3:29 PMpls says:
Very cool!
Oct 11, 2008. 1:53 PMKeith-Kid says:
I love it! I bought some new LEDS just for this!!!
Oct 6, 2008. 8:30 AMpeachlover says:
may i ask how long the batteries will last? thanks.
Aug 19, 2008. 12:14 AMecctao says:
very sapiential thing for play
May 11, 2008. 10:53 PMcombot55 says:
omg the 2nd vid looks like u cast Magic Missle lolz DO IT FASTER!!!
Jul 20, 2008. 4:27 PMmage says:
alas, thy can begin mage career. i should build one with red and orange to give the illusion of mario's fireballz
May 14, 2008. 2:09 PMawkrin says:
yeah, it kinda looks like that, but AI can simply increase the framerate to make it look faster
Apr 20, 2008. 7:00 AMBrennn10 says:
Wow, those look really neat! Nice job!
May 3, 2008. 11:22 AMawkrin says:
wouldn't it be more fun to add a low speed motor with a weight, and make that thing spin by itself, at least in a circle? a counterweight is probably needed on the other side lI mean like that:
May 8, 2008. 7:08 PMmusicalbee2003 says:
Or take a zip pull, put it around the axel of the motor, and let it push against the ground, like an elecric Cotton reel tank
May 7, 2008. 5:20 AMawkrin says:
u mean that's good?? it took my like 10 min and I didn't even rendered it anyways, I use google sketchup. it's really easy to use and u can render the images with some add-on(forgot the name).
Aug 30, 2008. 1:56 AMwezdog1 says:
Dude, sketchup? why that when you could used decent software like solidworks, pro desktop or even (if you had one million dollars), Catia. Nice instructable though!
May 5, 2008. 8:08 PMmwwdesign says:
Looks to me like it was modelled in 'Rhinoceros 3D', and rendered using 'Penguin'... if it wasn't, it could have been!
May 7, 2008. 10:11 AMawkrin says:
what do u mean in: "if it wasn't, it could have been!"?
May 7, 2008. 4:05 PMmwwdesign says:
I meant if it wasn't done using Rhinoceros 3D/Penguin, then you could get the same effect by using Rhinoceros 3D/Penguin. You can download an evaluation version from their site to try it out. www.rhino3d.com. I use it for work.
May 8, 2008. 1:33 PMawkrin says:
doesn't Rhinoceros 3D/Penguin mean exactly Rhinoceros 3D/Penguin?
May 8, 2008. 6:04 PMmwwdesign says:
I give up.
May 10, 2008. 3:55 AMawkrin says:
yeah, I've always been good at annoying people..
May 3, 2008. 11:15 PMsnagglebeard says:
another simple wat to make it roll would be to have some type of foot attached to the motor instead of a weight and have the foot hit the ground and kind of drag and the motor and the whole rollie thing woud spin and the foot would stay stationary. then you could use a high speed motor. I think two motors would be needed tho... and i also suppose that its alot of bs to go threw for a lighted spool... but then again if you unleashed a whole fleet of the things on a large parking lot, or a street, mabey at the mall...better yet the second story, now thats worth the effort
May 8, 2008. 1:28 PMawkrin says:
nah it won't work. it'll have to "scrape" the surface it touches, so I think the weight or nothing at all is better
May 25, 2008. 8:27 PMsnagglebeard says:
yes it does work I've built something similar to this for a school project. It was a two wheel vehicle for a hill climb. It had a single aluminum rod about an 1/8th thick and it was at about a 35 degree angle below horizontal with a small upward bend at the part where it made contact with the ground it was far lighter than building a third wheel and the body to support it.
May 26, 2008. 4:34 AMawkrin says:
sorry then..
May 3, 2008. 9:38 AMApplebohn says:
The rolly is an awsome idea, but on step 5 shouldn't it be they fit to perfectly?
May 4, 2008. 1:35 PMApplebohn says:
well you said "the fit so perfectly" and don't you mean they fit so pefectly.
1-40 of 86next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
91
Author:Artificial Intelligence
Hi all, I'm a college student in the copenhagen technical college. I'm currently working with 3D printers and I'm building my own RepRap.
