3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Sinkies
LED Sinkies
Just like throwies, only waterproof.
This is my first instructable so tell me what you think, or improvements.
First you will need...
1.Tape (Clear)
2.CR2032 3V Lithium Batteries (2 batteries per LED)
3.10mm Non-diffused LEDs.
Step 1FIRST
FIRST
First, you need to create a throwie, which can be found here,
http://www.instructables.com/id/E9D2ZJ3FG0EP286JEJ/
The picture is diferent than my finish, cause i couln't get a picture of the one that i was making.
How to make a Throwie...
1.Stack two batteries on top of each other and sandwich them between the legs of the LEDs. Use a few inch long strip of the tape to hold them on completely.
25 comments
Oct 8, 2010. 4:28 PMcatman0321 says:
great idea footballgirl004
Dec 4, 2008. 12:00 PMpyro man says:
wats the difference between diffused and non-diffused leds.i know that diffused lights up the color it is,but i mean performance wise.
Dec 5, 2008. 1:50 PMpyro man says:
thank you!
Aug 15, 2007. 8:49 PMWard_Nox says:
I came up with somthing similar using a capsule toy machine capsule i called it a depth charge I only have one detail to work out wich is why it's not up yet (im trying to figure out an on off switch)
May 19, 2008. 6:52 PMscienceguy says:
you could also use a reed switch. My uncle took a RC sub and put a camera in the front with a battery. He put a reed switch in it. To turn it on he just stuck a small magnet on the outside.
Oct 15, 2008. 12:19 AMWard_Nox says:
hmmm i had forgotten about this was looking at my coments list today im gunna have to chart this out and see if i can figure it out
Apr 28, 2008. 11:28 AM187inc says:
water proof switches, for boats, they are like $2 at west marine or your local boating store, maby even camper world and sometimes walmart
Aug 16, 2007. 12:26 AMWard_Nox says:
thx once i get the whole thing worked out i'll post it up. Iv'e already thought of a bunch of uses ie. being aable to drink a glowing bubbling potion in a haunted house how awesome would that be):->
Jul 7, 2008. 8:26 AMRadioactive_Legos says:
Hey, you should coat it in silicone that comes in a tube or hot glue. That way you could be sure it is waterproof. Just make sure the LED itself is not covered so you can recover it after the battery dies.
Jul 7, 2008. 1:24 PMRadioactive_Legos says:
Sort of...
But you can cut up the silicone and scrape it off the leads. Once I receive my LED throwie kit from the Let it Glow contest, I'll try it and maybe make an Instructable on it ;)
Feb 18, 2008. 7:57 AMHuntman00 says:
video tape the fish trying to eat it I want to see
Feb 17, 2008. 9:26 AMHuntman00 says:
tie the throwie to a fishing pole and put it in the tank (do not put a hook on it)
Feb 18, 2008. 7:56 AMHuntman00 says:
i am seroise
Sep 19, 2007. 4:11 PMMocabai says:
I've got and idea =). theres an instructable on a "ice jewel" or something named like that where you make a water balloon then half freeze it so the center is still water. you could add some of these as well as some floaties and would look awesome =). (sorry for the sucky grammar)
Aug 2, 2007. 6:50 PMfootballgirl004 says:
instead of tape why not try like a ziplock bag or glad press and seal
Jun 28, 2007. 6:36 PMtrebuchet03 says:
Hello, and welcome to the Instructables community!
This currently does not meet our criteria for an Instructable. A completed Instructable:
- details a finished project with instruction (not just links to instructions)
- has clear images that you took of your project (web-found clip-art is not acceptable)
- uses proper spelling and grammar
- contains appropriate cautions or safety considerations
- does not violate someone else's copyright
- does not violate the Instructables terms of service
- is typically written about something you are very passionate about and want to share.
If this is a comment, a question, a small tip, or something that cannot truly be a finish project, please post it as a forum topic. If you are looking to start a collaboration, post a topic in the forums.
Look here: http://www.instructables.com/id/ELHMNOA69REUF10WM7/ for tips on writing a great Instructable.
So, it has been unpublished. Please do not republish until it has been corrected. When you republish, if everything is fixed, I'll remove this note. Multiple attempts to republish without correction will result in deletion.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Hoboman
I'm 6'2" at the moment, and I love to build stuff. Most of the stuff that I build gets me in trouble, but it never seems to happen at school :D I'm an avid gamer, and love computers (I'm proud to say...
more »
