Step 5Attach the Driver or Resistors to the LEDs
If a LED controller is being used:
- Construct your driver using This Instructable or One of your choosing.
- Solder the wire leads of the LED's into their correct holes on the driver.
If single Color LEDs are being used:
- Its usually best if each LED gets its own resistor, but otherwise a single larger resistor could be used. This Calculator can be used to calculate resistor values or Contact Me
*Auto-Change LED need their own resistor for each LED.
- Solder the resistors to the LEDs and connect them in parallel.
- Or solder all the LEDs in parallel and place the large-wattage resistor in series with V+.
Prepare the PSU:
- For this I am using a 5v 500ma USB charger. Modifying a wall-wart style PSU as I am, is not suggested, do so at your own risk.
*Otherwise My Store has 5v @ 2A Power Supply with matching panel mount barrel jack, its would be a lot safer.
for the USB Charger:
- I removed the plug blades and replaced the wires with longer ones, blue wire in the images.
- I then soldered some dual strand 20ga speaker wire from V+ & V- to the respective holes on the driver board.
Add Comment
