3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Star Beam Clock
Step 6Switch for the LEDs
Switch for the LEDs
Since the clock will always be on, and the LEDs should not always be on, I added a rocker switch to the bottom of the clock that turns off the AC to the PSU.
- Place some masking tape in the spot the switch is going to go.
- Mark the outer dimension of the switch.
- Use a hacksaw or rotary tool to carefully cut out the switch.
The switch I used is pressure fitted, so it will hold itself in place as long as the hole is the correct size.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
63
Author:ChromationSystems(www.chromationsystems.com)
Designing electronic creations from microcontrollers, LEDs and anything else I can pull out of a dumpster and make use of. Check my Profile
