Safety and health warning: This project uses power from the mains ("wall outlets") which have dangerous voltages. Do not attempt this project if you are not familiar with basic electrical safety practices. If you ignore this warning, you may die, and it will hurt the entire time you are dying.
Metric conversions: Dimensions herein are in the archaic English system. Sorry, I am American. There are 25.4 mm to the inch. Have fun converting. Screw sizes are roughly equivalent, that is, a Nr 4 screw is about 4mm in diameter. I think.
MATERIALS:
1 swingarm desktop lamp
4 LED Lamps approximately 1 3/4 inch diameter
1 white PVC pipe tee, 2 1/2 by 2 inch
3 white PVC pipe caps, 2 inch
1 push-push fan switch, two-way, brass
PC wire cable bundle tubing, about 2 1/2 feet
22-gauge insulated wire in two colors, about 8 to 10 feet
4 wire nuts for 12-16 gauge wire
1/4 by 1/4 brass angle, about 2 feet
Metallic spray paints (I used bronze, copper, brass, and antique bronze)
Metallic touch-up paint (I used copper)
Small paint brush
Clear nail polish
6 Nylon zip-ties
Silicon sealer, one small (4 oz.) tube. I used white.
4 brass wood screws, Nr. 6 by 1/2 inch
2 brass wood screws, Nr. 4 by 1/2 inch
2 brass wood screws, Nr. 4 by 3/8 inch
2 brass machine screws, 6-32 by 1/2 inch
2 zinc-plated nylon-insert locknuts, 6-32
8-10 inches of heat-shrink tubing, small (for 16-22 gauge wire)
Tools:
Assorted tools for electrical work (soldering iron, solder, multimeter)
drill
screwdrivers
long-nose pliers
saw (I used a table saw and a hacksaw)
alcohol (for cleaning, not drinking)
disposable vinyl gloves
Remove these ads by
Signing UpStep 1Getting started: Pick a lamp
Add Comment
