Here I have used a discarded Li-Ion Battery which is no more working in a mobile handset.
This Battery may not work in a mobile set but it has got a lot of juce left in it to run a small poket size rechargeable TORCH with 5 LED's. It gives a very bright light and does not need a recharge for quite a long time.
Remove these ads by
Signing UpStep 1: STEP-1
1.- One PVC flat Box of size 2 x 3 x 1/2 Inches.
2.- One Single pole single throw switch.
3.- Five Very bright White LED's of 5mm size.
4.- One Discarded 3.6v Li-Ion Battery. (Lithium Battery)
Visit Our Store »
Go Pro Today »
thats nice thing buddy.very good
can we use li-polymer 3.6v type CBA-0001003B?
Just a question, how did you connect the wire ends to the battery contacts? were they soldered?
Thanks!
I was thinking along those same lines, as I was reading this 'ible.
then I looked in my electronics junk, er, recycle pile, and inspiration hit.
My solution will indeed recharge, even the larger cellphone batteries.... but it'll probably take a LONG time. My palm treo battery has roughly 9 times the mAh rating, and I don't think my converted "toys" do ANY kind of quick charging. I think they are full-time trickle chargers, with a "full battery shutoff" circuit.
.... so you say to connect the LEDs in parallel but mention nothing about using resistors, because this article --> http://www.kpsec.freeuk.com/components/led.htm <-- advises against connecting them in paralel, or at least use a resistor for each LED.
Feedback needed. Thx.
Right side is (-) Left side is (+) marked on the battery
The MIDDLE connection is for the CHARGER, it decides what type of charge to give to the battery at what time. It reads the condition of the battery.
SEE ----------- How to Charge a Li-Ion Battery.
good idea though
this will make the leds go miles higher and with no noticeable difference of brightness.
