it is an appropriate technology
power save up to 80 %
Easy to make ,
No Maintenance
Specification
Watt - 1.5 watt
Input - 230 volt AC / 50 Hz
Light - White Cool
we can use it as
-Table Lamp
-Night Lamp
For more detail or information
Contact with me on
Hiren Panchal
hirenpanchal47@gmail.com
call me on +91 (0) 9099607558
Remove these ads by
Signing UpStep 1Doing home work
You join Bridge diode with Capacitor & Resistors with led's..ok?? but by this way...led's light gone down in some times. For making it for long life...must be required SMPS power supply. by using SMPS Led's light & life must getting maximum. By using Bridge diode circuit...sometimes capacitors or resistor will be heat or burn....& blast also some time & its negative point is if you give more than 250, circuit or led's must fused or damaged. So better way is using smps power supply & dont use more led's...1 watt led giving same light of small 40 Led's.
Prashant - surat(guj) india
just my opinion(and obviously some others judging by the comments)
remember people, PLAY NICE, and comment nice.
Who is vetting these "I done it without showing how" teases?
& just you say " I done it without showing how "
that mean you can do , so why you required Instruction ?
I have put this images for guidance only . for some one who intrested in this field ,
& i will update this Instruction very sooooon ,
Thank for your Comment
Considering your instructable refers to 240V mains electricity then it is very important you provide instruction otherwise someone could try and guess a solution and electrocute themselves.
