LED Throwie Talkie by pcunning
Featured
Maker Fair Mashup: G.R.L. LED Throwie + Cybords = Throwie Talkie
During the 2006 Maker Fair the Graffiti Research Lab was demoing their LED Throwies and Pat & Ward Cunningham were demonstrating Cybords. While talking someone made a comment about wanting to give the Throwies a voice. Ward & Pat took a simple ATtiny45 chip and added it to the mix to give the LED a voice. Computerized Throwie Demo
Step 1: Get the Supplies
You will need:
<ul><li>10mm Diffused LED
<li>Programed ATtiny45 Computer
<li>CR2032 3V Lithium Battery
<li>1/2" Dia x 1/8" Thick NdFeB Disc Magnet, Ni-Cu-Ni plated
<li>1-inch wide Strapping Tape
</ul>
For a more complete parts list see: LED Throwies instructables page
Step 2: How we program the chip
We program the ATtiny45 chip using this and Atmel Avr Tools.
Step 4: Solder the leads
The chip is programed in a way that we can solder the LED leads right across the chip. The best way to solder them together is to hold one side with nedle nosed plyers and tap the other side with some solder.
The longer LED lead should be soldered to the 'vcc' (power) and 'rst' pins of the chip. This shorts the chip reset and gives it a more secure conection. Make sure to reference the wiring diagram in this step to get the pins correct.
Step 5: Snip the Ground
Next you have to snip the LED lead betwen the ground and control pin so the chip can compleet the conection and make a message.
Step 6: Conect battery
wedge it inbetwen the two leads.
Step 7: Stick it!
This is the easiest and most fun.
1-40 of 123Next »
Razoracanine says: Aug 21, 2010. 8:50 PM
can i use audio amplifier?? it is the same..
zerozz says: Feb 28, 2008. 2:36 AM
Here is my modified version of the Throwie Talkie actually sending Morse code over the air waves on ham radio. This project has been a lot of fun and I am still coming up with ideas for it's use. It's not just for decorating a bus and it's not expensive trash. Some people just don't have an imagination. :)
Image 1:
http://pages.prodigy.net/kg0zz/mini_digital_cw_keyer/mini_digital_cw_keyer1.jpg
Image 2:
http://pages.prodigy.net/kg0zz/mini_digital_cw_keyer/mini_digital_cw_keyer2.jpg
See the video:
http://pages.prodigy.net/kg0zz/mini_digital_cw_keyer/mini_digital_cw_keyer.wmv
hannahheartsyou says: Apr 23, 2008. 6:18 AM
ham? I LIKE HAM!!!!!!!!!!
mettaurlover says: Jan 6, 2009. 12:28 AM
AND CHEESE!!!!!
Tobita says: Mar 21, 2010. 8:00 PM
I *hate* green eggs and ham...
mettaurlover says: Mar 21, 2010. 8:10 PM
Agreed. And I don't even know why I said what I did above. I guess I was high on sugar.
robby worthless says: Jan 5, 2010. 6:47 AM
where can buy rogramed ATtiny45 Computer?
jpr55 says: Jul 29, 2009. 6:29 PM
How do I get the ATtiny13v programmed? Not sure I understand that step. Can anyone help? I have a son who is learning Mores Code and this would be a fun way to either drive him crazy or help speed up the learning process.
godofal says: Nov 12, 2009. 5:52 AM
easiest is (for me it is) a ghetto programmer, u can make one cheap and u will probably (if ur hobby is electronics) have the stuff (except maybe the Dsub connector)
all you really need is a computer with a paralel (printer) port.
check this instructable, its what i based mine on:
http://www.instructables.com/id/Ghetto-Programming%3a-Getting-started-with-AVR-micro/
and mine, wich is basically a cradle that i can change the connections on:
http://www.instructables.com/id/ghetto-programmer-improvement/
jjam100 says: Aug 22, 2009. 2:31 AM
this is wicked ill make one right away
agis68 says: Jul 20, 2009. 11:49 PM
interesting project for further analysis. You see that makes me to think about to built a led flasher that sending SOS with a bright LED that blinks with the appropriate rate and u can see for far away. Now if you pack this in a water proof kit then this is life saving project and anyone will have it when travels with any surface vessel. Think about it!
blackfister says: Jul 4, 2007. 9:56 AM
Interesting throwies. I have a question/comment/propousal.... Having seen the throwies, and this talkies... I understand there is a sound frecuency that only people under age 24 can hear, I have a mean idea, that is to make many throwies that emit a sound in this frecuency, and hence clean areas of young people. Is this possible? Any one knows how to do so? anyone intested in teaming up if this is possible? martin
jeb3518 says: Jul 7, 2009. 9:50 AM
I know exactly what your talking about. I'm in my late twenties and apparently haven't lost that part of my hearing yet. In fact, my dentist uses a new high-frequency sonic drill now for cleaning teeth. Every time I go, I get this painful very high frequency squeal in my ears. I asked him about it and he said that a few of his younger patients have complained about it too. If there really is a young person sonic "deflector" or whatever, it would drive me insane, and I would avoid that place like the plague. In fact, I wouldn't mind loosing that ultrasonic part of my hearing. The only time I notice it, it's either really annoying or just flat out painful. Although, maybe it is useful and I just don't know it because I've always had it and don't know what it's like without it. Oh well.
alliegator555 says: Apr 29, 2009. 6:24 PM
actually i rememeber reading somewhere that some shops in some countries do do that and i do think its a bit rude but unfortunately i can understand y u would want ppl my age out some places...
sgt.paper says: Jul 7, 2007. 12:42 AM
were do u get the program thingy?!?!?!?!?!?!?
MrZim4 says: May 3, 2009. 6:02 PM
doesnt it need a speaker to be able to hear the voice?
temp says: May 11, 2009. 3:13 PM
it's sending it out in morse code, so the led turns on and off.(in morse code language) The whole "let the led throwies be heard" Just means allow some way of sending a message.
MrZim4 says: May 11, 2009. 9:16 PM
ok that makes sense...
Derin says: May 2, 2009. 10:39 AM
Instructables does not allow HTML coding in guides(there is a secret way though),instead you use Wiki formatting.
* Lists are done* like this.* They turn out * pretty much like* EXAMPLE:
  • Lists are done
  • like this.
  • They turn out
  • pretty much like
  • EXAMPLE:
motorbreath says: Jul 8, 2007. 5:18 PM
whats the point of this
IDTL says: Feb 25, 2008. 2:10 AM
Fun.
YummyPancakes says: Mar 11, 2008. 1:36 PM
The point of everything is fun! XD
ollis118 says: Apr 27, 2009. 9:14 AM
Yummypancakes your youtbe account??
YummyPancakes says: Apr 29, 2009. 2:06 PM
TheCh0senGamer, and proud of it. If that's what you were asking.
america_sly says: Apr 15, 2009. 12:01 PM
i would like to know whre to get all this
raykholo says: Mar 22, 2009. 8:28 PM
maybe a morse code decoder using a photoresistor would properly finish off this project...
twitsl says: Feb 26, 2009. 1:39 PM
I would add a piezo to it so it can actually talk!!!!!
Arbitror says: Dec 2, 2008. 5:10 PM
That is one
BIG
LED!
Or you just have small fingers!
mettaurlover says: Jan 6, 2009. 12:18 AM
or maybe the LED is just closer to the camera. you ever think of that?!? sorry, i'm going crazy with sugar and caffine right now.
wackyvorlon says: Nov 1, 2008. 10:46 AM
I was thinking, you could make it a fair bit smaller using the SOIC variant.
rmd6502 says: May 1, 2006. 3:48 PM
A really interesting mod for this would be to add iDropper (don't have the URL handy, but "iDropper LED" returns it as the first link) functionality, which lets you use the LED as an input device (!). You could then, for example, change the blink pattern after deployment, or sync a whole wallful of throwies for additional impact. I believe Digi-Key has the attiny11 in bulk quantities for about a quarter apiece...
Ian01 says: Jul 14, 2006. 9:30 PM
It gives your comment as the first link, and nothing else relevant. So, what's an iDropper?
technodude92 says: Sep 3, 2008. 6:55 PM
http://www.merl.com/papers/docs/TR2003-35.pdf
Read through it, it's 19 pages but very interesting.
pcunning (author) says: May 1, 2006. 5:10 PM
Using the LED as an input device and using a cheaper chip are two things we are looking into for future Talkies. (We also have some other ideas - more to come)
rotor says: May 1, 2006. 3:52 PM
what would be actually interesting would be to use these things as random data storage that you can pick up with an iDropper. This might actually make the placement of them interesting beyond the "ha ha, this is going to irritate someone" aspect of it that everyone seems so enchanted with.
technodude92 says: Apr 28, 2008. 6:46 PM
HEY! great 'ible. simple, clean looking finished product. i love it(+)
DarkStar851 says: Feb 26, 2008. 1:59 PM
Takes away from the simplicity of the Throwie idea. Good luck making these in bulk to throw on a bus! :)
zerozz says: Feb 1, 2008. 3:46 PM
For the newbie (like me), this is how I made this project. Although this project is quite simple to make, you will spend a lot of time learning something new. If you would like to take time to learn how microcontrollers are programmed and enjoy a challenge then you'll love this project. I went the less expensive route and followed the link on Ward's web site and bought the UsbTinyIsp programmer kit. After building the kit, I then downloaded the software and drivers for it and followed the UsbTinyIsp manufacuturer's instructions on how to burn a hex file to the Atmel Attiny45 chip and how to wire a "target board." Next, I had to learn how to "assemble" the files. I then downloaded the Atmel AVR Studio 4 (click the AVR Tools link in Step 2) and read the file for beginners, http://www.atmel.com/dyn/resources/prod_documents/novice.pdf . After reading this file, the morse.asm file began to make much more sense to me. All I had to do then was copy and save the bynase include files (from Ward's web site) to the Atmel App Note folder on my computer and paste the text from morse.asm file to a new project in AVR Studio. The Atmel novice tutorial will guide you in creating the hex file for you to burn to the chip. When you save the files, you may need to rename them, i.e. to save "bynase2.inc", click "save" then select "all files" for the file type and save as "bynase2.inc" instead of "bynase2.inc.txt". To find the Include files on your computer after installing AVR Studio 4, just search your hard drive (C:) for all files ending with ".inc", (i.e., Click Start, Search and enter *.inc). After finishing this project, you'll be well on your way to learning new microcomputer programming skills! :)
kennerow says: Jul 23, 2006. 8:05 PM
How long does the battery life last?
songbirdspectre says: Nov 23, 2006. 12:07 PM
im not sure with voice, but most LED lights last two weeks on this type of battery. :)
1-40 of 123Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
