Maker Fair Mashup: G.R.L. LED Throwie + Cybords = Throwie TalkieDuring the 2006 Maker Fair the Graffiti Research Lab was demoing their LED Throwies an...
You will need:10mm Diffused LEDProgramed ATtiny45 ComputerCR2032 3V Lithium Battery1/2" Dia x 1/8" Thick NdFeB Disc Magnet, Ni-Cu-Ni plated1-inch wide...
The chip is programed in a way that we can solder the LED leads right across the chip. The best way to solder them together is to hold one side with n...
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
