Click on this link to see the LED Throwies in action in NYC thanks to resitor and fi5e!
Remove these ads by
Signing UpStep 1Materials List
Part: 10mm Diffused LED
Vendor: HB Electronic Components
Average cost: $0.20 avg per LED
Notes: Cost reductions for larger quantities. Comes in red, blue, amber, white in both diffused and clear. Diffused works better than water clear for the Throwie application. HB has even created a Throwies packs page with deals on 10mm LEDs and lithium batteries!
Part: CR2032 3V Lithium Batteries
Vendor: CheapBatteries.com
Cost: $0.25 per battery
Notes: Cost reductions for larger quantities. With the 2032 Lithium batter, depending on the weather and the LED color, your Throwie should last around 1 -2 weeks.
Part: 1-inch wide Strapping Tape
Vendor: Your local hardware store
Cost: $2.00 for one roll
Notes: One roll will make many throwies
Part: 1/2" Dia x 1/8" Thick NdFeB Disc Magnet, Ni-Cu-Ni plated
Vendor:Amazing Magnets
Cost: $13.00 per 25 magnets
Part: Conductive Epoxy
Vendor: Newark In One
Cost: $32.00
Notes: The epoxy is optional.
| « Previous Step | View All Steps | Next Step » |
Here's the link: http://flickr.com/photos/everythingdigital/sets/72057594069888500/
I'm also working on throwies that automatically turn on upon sticking to something and off when they are removed (as suggested above), and I have a few prototypes working but there are still some bugs to work out.
Throwies on steroids -
The LED ULTRIE!
7 LEDs arranged in a ring
For winning you are receiving a 3 month pro-membership.
http://www.instructables.com/community/June-is-I-Made-It-Challenge-Month-Win-a-Pro-Mem/
Thank you for sharing such great information with us. I really appreciate everything that you've done here and am glad to know that you really care about the world that we live in
Search Engine Optimization
And if not, what do you think would be the best battery to use to keep the LED throwies lit for over 12hrs?
I'm really new at these things, so the best terms to use, would be the basics. I'd appreciate it if you could even point me in the best place to buy what I would need to make them light up at dusk.
Thanks!
0.02 x 20leds = 0.4amp per hour
0.4x24 hour per day = 9.6 amp on 3v for one day,
if you have a battery pack, 4AA batteries, 6volts, and the best amp possible (actually 2.7) , you can hold around 13hours,
with a car battery(12v 60Amp) , with 5x4 leds, you can hold 25,71 days
(12*60)/(9.6*3)
hope that it's right, and that it helps you ;-)
Is this particularly common? I'm hoping to let people choose their own colors for an LED project, so I'm not intending to attach all LEDs to a battery in advance of the project.
If you know any good tricks to avoid letting the cathode lead from contacting the positive side of the battery, what are they?
In the end it doesn't matter as long as you keep your conventions consistent and know how to correctly wire up circuits in practice.
They arent rares, which you can see from the price (though they arent free)
IT Contractor Mortgages
I will be sure to let you know if I do.Great work! Dropshipping
It depends on the LED (+++Brightness=+++Power used) and the battery used. LEDs can last quite a long time before burning out so the problem is the battery. Using a higher capacity or adding a resistor (bigger batteries will make the Throwie bigger and heavier and resistors will lower the brightness. This is why people want to make them with solar cells and photoresistors. Solar cells gather the energy and photoresistors will tell when it is dark enough.
