LED Throwies
Step 1Materials List
Materials List
LED throwies consist of only a few inexpensive parts and can be made for ~$1.00 per Throwie. You can reference the parts list below or download the attached spreadsheet for more info on parts, part's numbers, vendors and application notes.
Part: 10mm Diffused LED
Vendor: HB Electronic Components
Average cost: $0.20 avg per LED
Notes: Cost reductions for larger quantities. Comes in red, blue, amber, white in both diffused and clear. Diffused works better than water clear for the Throwie application. HB has even created a Throwies packs page with deals on 10mm LEDs and lithium batteries!
Part: CR2032 3V Lithium Batteries
Vendor: CheapBatteries.com
Cost: $0.25 per battery
Notes: Cost reductions for larger quantities. With the 2032 Lithium batter, depending on the weather and the LED color, your Throwie should last around 1 -2 weeks.
Part: 1-inch wide Strapping Tape
Vendor: Your local hardware store
Cost: $2.00 for one roll
Notes: One roll will make many throwies
Part: 1/2" Dia x 1/8" Thick NdFeB Disc Magnet, Ni-Cu-Ni plated
Vendor:Amazing Magnets
Cost: $13.00 per 25 magnets
Part: Conductive Epoxy
Vendor: Newark In One
Cost: $32.00
Notes: The epoxy is optional.
« Previous Step   View All StepsNext Step »
99 comments
1-40 of 99next »
May 21, 2010. 7:37 AMmakerboy112 says:
You can buy ten rare earth magnets at Harbor Freight for 2 bucks
Jul 11, 2009. 6:09 PMjhames says:
For someone that would prefer not to shop online what electronic stores carry LEDs? Lives in the US.
Jan 15, 2010. 4:31 PMlgraham938 says:
 I got mine at Radio Shack
Dec 15, 2009. 3:08 PMGlockenator says:
radio shack would be the best. and it was the best in canada til they closed every canadian store
May 18, 2010. 5:48 PMsammyd901 says:
In my experience radio shack overcharges for everything. I only stop in if i need something fast that i cant find online.
May 9, 2010. 9:39 AMzack247 says:
yeah they replaced it with "the source", even though, in the store closest to me, they dont know anything about anything, and they have hardly any electronics parts, they have just about a wall thats 6' by 6', and most of the things are protoboards and project boxes, and the only chip they have is the 555, not too much you can do with that.
Feb 22, 2010. 6:32 AMkilller64 says:
radio shack is realy expensive tho
Jan 13, 2010. 3:09 PMphilipwoodall says:
 actually they just changed the name to the source, radio shack still owns them.
May 9, 2010. 3:00 PMsawatzky says:
??? RadioShack Canada was own by Tandy Corp. And Licensed the RadioShack name. CircuitCity Bought Tandy, and RadioShack refused to renew the license to it's competitor, CircuitCity so CircuitCity just called the old Canadian RadioShacks "The Source from Circuit City". So are you saying that RadioShack bought CircuitCity???
Jul 16, 2009. 9:25 AMRane says:
Radio Shack usually has some stuff.
Jul 17, 2009. 7:38 AMTobz1122 says:
what about England?
Jan 25, 2010. 10:00 AMnadina says:
 You can get this in Europa at www.ozhobbies.eu/.
The cube throwies are pretty cool.
Aug 4, 2009. 3:12 PManonymouse197 says:
Maplin
Nov 30, 2009. 7:40 AMMinifig666 says:
 Or Rapid Electronics (Google It)
Maplin is sometimes more expensive but the convenience of its store's makes it better.
Jul 17, 2009. 8:10 AMRane says:
I dunno, never been there. Lol.
Mar 2, 2010. 6:48 PMllamma1010 says:
umm i think you should update the price on the epoxy it now costs 59.97!!!!!!!!!!!!!!!!!
Jan 7, 2010. 2:43 PMM4industries says:
 The led's are about $0.16, but you have to order $25 worth!
$25/0.16= 156.25 (Rounded to 157) LEDs!
I don't need 157 LED throwies.
Sep 26, 2009. 6:48 PMmechanismango says:
so when it says its a 1.8v - 2.4v LED will it still work with a 3v battery or what? Will it just burnout faster?
and of http://www.kjmagnetics.com/products.asp?cat=17 or http://www.gaussboys.com/magnets/discs/ which magnet is best? a 10mm by 2mm?
Oct 13, 2009. 3:53 PMscld says:
That voltage rating is for the LED itself. Basically, when it is turned on, there will be 1.8-2.4V across it. So, you need at least 2.4V for the LED to turn on (preferably a little more).
However, you usually don't want to have just an LED and a battery. You want to have a resistor in front of it, too (It's OK in this case because you're using a 3V battery with a 3V diode, so it's pretty close).
In your case, I would put a 30 Ohm resistor in series with the diode. The diode will drop 2.4V and the resistor will drop the other 0.6V. The resistor will cause about 20mA of current to flow through the diode, which should be enough to turn it on!
Nov 19, 2009. 10:38 PMimarzouka says:
scld is right.. you will need to add a resistor in this case so that the LED won't burnout.
Just enter your led specs and battery voltage here: http://ledcalculator.net and it will tell you which resistor to use.
Sep 29, 2009. 6:44 PMmeghann says:
So are the magnets necessary if I'm just wanting to add LEDs to a costume (I'm new to this...so the lights will glow, without the magnet?)
Jan 25, 2010. 6:55 PMjensenks says:
Oh, yeah!  The magnet is solely for sticking.  We hooked up 6 LEDS to one battery today and they worked great.  We're going to extend them with wires so they won't be bunched up for a model we're putting together.  One thought on your end - would it help to use white duct tape (better than your standard siver stuff) to fasten your lights to the costume.  Good luck with your project!
Oct 13, 2009. 12:54 PMbassclarinet23 says:
Magnets are not necessary if you don't want it to stick to something. You only need an LED and a power source, though a switch would be useful if you want to be able to use the costume again (long term), plus it saves battery.
Oct 9, 2009. 9:46 AMfirezone says:
and you dont have to do the same as here, you could wire up a long line or web of led's and power it with a slightly bigger battery, that would take a lot less money and time
Oct 3, 2009. 9:24 AMgodofal says:
yes, leds only need power to light up ;)
Oct 15, 2009. 6:48 PMbassclarinet23 says:
What are these "rare earth magnet" things? I've seen them onmany projects, nut how do they differ from magnets, let's say, from aMagnetix toy. (I don't mean to sound rude, I'm just curious.)
Nov 8, 2009. 7:41 AMpaperclip32 says:
 they are made from neyodinium(?) and are extremely strong.
Nov 8, 2009. 10:35 AMbassclarinet23 says:
Okay, thanks.
Oct 15, 2009. 7:53 PMYerboogieman says:
Strength, metals they are made with, tons of things. Crack open an oldhard drive.
Oct 16, 2009. 12:46 PMbassclarinet23 says:
Okay, thanks for the information.
Jun 20, 2008. 7:47 PMREA says:
the magnets are alot cheaper herehere
Jul 21, 2009. 5:14 AMxfnord says:
Thats more expensive the the price for a complete led throwie. check this out[]
Jul 21, 2009. 9:54 AMREA says:
>Jun 20, 2008.
it was cheeper a year ago when i posted...
Aug 2, 2009. 3:52 AMxfnord says:
hmm - right you're message is one year old :) did not realized that
Aug 7, 2009. 12:40 AMchemfiend4568 says:
check out their surplus magnets. 2 zd1 or 1 zd2 magnet would do the job, and they're pretty dang cheap in bulk
May 20, 2009. 1:01 AMGeo242 says:
The link you posted now shows magnets between $.50 and $.60 each for orders less than 100, but it may have been cheaper when you posted it.
May 20, 2009. 8:38 PMREA says:
oh wow! it was about $0.19 per magnet when i had posted that.
Jul 20, 2009. 12:36 PMRedgerr says:
prices change ;) wish you ordered 100000 of them now? :P
Jul 20, 2009. 5:04 PMREA says:
yes... ='(
May 22, 2009. 9:44 AMlaurajean00 says:
also wondering if anyone could guess at how many throwies i would need to put in a lantern for an outdoor wedding reception?
1-40 of 99next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
213
Author:Q-Branch
I made weapons for the British government for over thirty-five years. Now that I am retired, I have gotten involved in outfitting graffiti writers and street artists with state-of-the-art technology. ...
more »
