Step 2Test the LED
Note that the positive terminal on the battery has a larger contact surface than the negative terminal. The positive terminal extends around the sides of the battery. Don't let the cathode lead of the LED accidentally touch the positive terminal of the battery. This will create a short and cause the LED to function improperly.
For more information on LEDs click here.
For more information on batteries click here.
| « Previous Step | View All Steps | Next Step » |
life status || miss you quotes || naughty quotes || romantic quotes
if it were entirely based on current limitation and not voltage, wouldn't hooking a 12V LED up to a car battery which is capable of pushing 300 CCA require a massive amount of resistance, compared to, say, hooking one up to 4 CR2303 batteries in series?
this is you web site :http://www.magical-led.com
Is this particularly common? I'm hoping to let people choose their own colors for an LED project, so I'm not intending to attach all LEDs to a battery in advance of the project.
If you know any good tricks to avoid letting the cathode lead from contacting the positive side of the battery, what are they?
