Step 7Other applications and upgrades
Other than tossing it, you can also use your LED throwie to write in the air with light while taking a long exposure flick. You can put them on your bike as an additional reflector. You can put the on surveillance cameras to make them more visible at night. You can use them to play a version of bocci ball on a magnetic surface in the dark.
Upgrades:
You can make a better LED throwie by using shrink tubing on each lead to make sure they don't short to each other or the battery. This upgrade will allow you to bend the LED so it faces in the direction you choose. You can also dip the throwie in epoxy, silicon or potting compound to make an all-weather LED Throwie. A resistor in series would allow you to increase the throwie shelf-life. Bigger batteries = longer life. Stronger magnets = increased stick probability. You could add a solar panel, photocell, etc...Have fun.
User Upgrades:
Flickr instructional set for thowie on/off switch mod -- by A. Joyce, aka. EverythingDigital
| « Previous Step | View All Steps | Next Step » |
They arent rares, which you can see from the price (though they arent free)
It depends on the LED (+++Brightness=+++Power used) and the battery used. LEDs can last quite a long time before burning out so the problem is the battery. Using a higher capacity or adding a resistor (bigger batteries will make the Throwie bigger and heavier and resistors will lower the brightness. This is why people want to make them with solar cells and photoresistors. Solar cells gather the energy and photoresistors will tell when it is dark enough.
See http://science.howstuffworks.com/electroluminescent-wire2.htm for excruciating detail.
That...Is...AWESOME
aren't the LEDs and batteries harmfull to the enviroment, just toxic waste once they're burned out???
Oh, and "throwies" isn't about being "cheap" and easily disposed of. It's a street art term about quickly done tags that look like they've been "thrown"
Example : "Hey [name], want to fill up your mops and put up some throwies?"
Oh, and this ible is awesome. The way we were making ours was wayyyy too complicated. Thanks!
second, where do you think the 'heavy metals' came from? the environment. you same argument is what makes getting rid of lead bullets idiotic. animals thrive in civil war battle areas, and there must be tons (literally) of lead on those feilds.
don't get me wrong, i think recycling is a good thing. but the only thing that we should really be worried about is synthetic materials. everything else already came from the earth. things like metal and cloth and magnets, those all are natural. if you picked up a rock, carved on it alittle, and left it somewhere, whould you recycle it? no, you'd just let it erode.
that said, while these throwies are fun, if you take it to an extreme, or put them in impossible to reach places, you are basically vandalizeing, and littering. the officails you're trying to wow may not be so pleased, particularly if you don't take them down yourself.
Waste for the sake of fun only increases thees problems. Despite the argument that "someone would use the batteries, and magnets", this is leading to an increase in pollution as yes they would have bought and used them but now they are buying others that need not have been produced if not for this prank.
For those interested, there's even a page in English about this whole program: http://www.bebat.be/pages/en/main.html
I suppose some ppl bring the environmental impact topic here as these throwies (as small their impact can be) is like a punch in the face, going exactly in the opposite direction a lot of people are trying to go in terms of leaving the disposable-society we're currently living in (disposable camera, shavers, toothbrush,...)
http://www.freezelight.ru
