3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Under Cabinet Lighting
  • last photo ←
Back in February, I started creating this design to have a "night light" or an under the cabinet light. I then thought, I already have custom under-the-cabinet lighting. Why should I change what lighting I already have, and it's only 6 months old. So then I decided to keep the design, and just put it under the shelves above my desk. Which would make it into a night light because my desk happens to be in my bedroom. So technically, it isn't under-the-cabinet.
Part List:
-Several LED's
-18 gauge wire
-Several resistors (matching the number of LEDs)
-solder/gun (optional)
-electrical tape
-wire cutters
-wire strippers
-a switch (optional)
-tape measure
-Multimeter
-Anything else that is mentioned
I am not responsible for any harm and/or damage you do to yourself and/or others; nor am I responsible for damage done to any material object. When you follow my instruction, I, neither is Insructables responsible for your mistakes or anything of that nature(s); You assume full responsibility.''
BTW: I get my LEDs from ABCTRONICS.COM
Viewers Note: I ran out of resistors. I only have half of my stuff lite, so understand that. I also didn't solder...I ran out of solder. Thanks!
Step 1Find a Power Supply
No pics of mine. You should find an AC to DC power supply. The input should be 120vAC and the output should be around 9vDC to 15vDC. You should be willing to destroy it. Cut the end that is 2 inches or so from the small cylinder. Then strip the wires. The wire (dotted or straight on) is the positive wire. Connect the + end to your switch. Solder if needed.
1 comment
Jan 28, 2010. 11:07 PMeyerobot says:
Maybe I missed it, But I didn't see the value of the resistors listed.
And did you do any of the current calculations?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:technogeek-1995
