HINT: start your soldering iron and hot glue gun now so they warm up
Remove these ads by
Signing UpStep 1What you will need
PARTS
- some ultraviolet LEDs, I used 4
-A small switch
-One resistor for each LED, Mine were 330 ohm
-Black tape/ Electrical tape
-Some wire
-Small plastic or glass container, This should be watertight and clear
-A battery, Mine was a 7.2 volt RC car battery
TOOLS
-Solder Iron
-Solder
-Wire cutters/ strippers
-Hot glue gun with hot glue
-Scissors
I had some stuff but I had to buy the LEDs ($2 Each) and the switch ($1 for a pack of 5)
Would be interesting to test this with proper cultures on petri dishes. Shame I don't have a lab / money / the scientific experience to do it...
TA DA
http://www.cardonalabs.com/UVLEDs.html
1 - UVC is germicidal, thats between 100 and 280nM
2 - most plastics and glass filter out UV light
You need to use Clear poly-styrene plastic or cobalt glass for UVC to pass through, or stick the bulbs into the water without anything infront of them.
I understand UV-C LEDS will cost more but would like to get hold of some to develope the idea with a view that the price will come down eventually. Anyone know where i can get some?
I wouldn't have thought the 400nm LEDS used in this design actually have any effect? Maybe someone could test using a coliform presence test? fairly cheap to buy. I got some for £3.50 ($7?).
The danger of that is you will think your water is being purified, when it is actually no different than when you put it in the bottle.
But unless you have a bio-lab at hand there will be no way of knowing.
Personally I'm going to stick with the store-bought purifiers as they get thoroughly tested - I don't want gastro in the middle of no where.
Feelin some "Blade Runner" kickin in....
..."Enhance"...String of UV LED's in PVC or Clear pipe of similar diameter with regulated water flow to allow for 30-60 sec of exposure to UV light....
..."Enhance"...Utilize Solar Panels or Wind Generators for power supply...
..."Enhance"...Add rain fed cistern, some sort of pre-filter to clear out the chunkies, use gravity to power most of the water flow, and some not-so-subtle electronic wizardry to turn the system intake water valve "OFF" when power from batteries to UV LED's drops below a certain limit, leaving enough lag time to purify that which is left in the system.
Viola...or, small cello...You now have a higher tech, more pure, more nature-friendly* system of water purification/reclamation.
