Remove these ads by
Signing UpStep 1Materials
The LEDs were from an assortment I bought from American Science & Surplus - your basic 1.7V to 3V red, orange, green, white/clear LED.
The 100 & 200 ohm resistors were from Radio Shack.
The 25mm Beading Hoops were from a local bead store and cost $4 for 10.
The only critical component are the batteries, which need to have leads pre-soldered to them at the factory. The 3V lithium-ion batteries were from Mouser (Mouser part #658- BR2032-1GU,mfr part #BR2032-1GU @ $2.32 ea).
Great idea!
They should be very handy at New Year's parties.
Now if I could only figure out how to make them blink...
- Bill
I did come up with a thought though - couldn't your use the smaller 3v (1cm) coin batteries and a surface mount LED and tape them to the underside of the base? That would put them shining directly up the center of the glass.
- Billr
http://www.ramseyelectronics.com/cgi-bin/commerce.exe?preadd=action&key=BL2
The nice thing is that they're small AND bright for the most part. :-)
u should, however order 2 or 3 leds/resistors if ur making 1 (dont count up like that, if ur making 10, order 15) since ul lose them very quick, even with a clean floor/workingspace...
and btw, leds always need resistors, even the green ones! u just need to calculate the right resistor, some only need 50ohm, while others can go to 300ohm
just google it, there are plenty of online calculators to use, instead of manually doing it urself ;)
and maybe add a tactile switch faced down, so the led will light up when the wine glass stands on the table, and goes off the second u pick it up :)
il try to make one of these when i get the chance, make some pictures and upload them
nice idea, nice projec!
- Billr
- Billr
but i was wondering if you had tried it without the pre-soldered leads and if u had if a 1.5V button cell battery will light up the LEDs well enough or if you have to go with a 3V battery
http://www.evilmadscientist.com/article.php/throw
, which says red & yellow leds require 1.7v and green & white leds require 3.5v.
I didn't try the 1.5v batteries, though. I'm sure that 1.5v batteries are available with pre-soldered leads.
Another option would be to use a battery holder and solder to that. I would appreciate a link to where I could purchase battery holders for a CR2032 3V lithium coin cell battery.
- Bill
Andrew...
Heat shrink was the first thing I tried but I didn't like the way it looked.
- Bill
