3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Zippo Flashlight
Step 5The Results
The Results
If it all came together the right you should have a working Zippo Lighter flashlight.  Show it off at the bar, tell all your friends, and please let me know what you think.
As I said at the beginning this was not my first attempt. Below are some pictures of my original prototype. I made it out of an old beat up Zippo at this point i put the switch at the bottom and used only one blue LED.
Instructable created by RJ Koharik
10 comments
Sep 19, 2010. 9:26 AMsashadistan says:
I have (literally) just completed this project. Thanks for the cool ideas. I ended up threading my positive wire through the other hole below the switch and you can barely see it. My solder joins were quite large.
This was my first electronic project since I was about 12 and now I am training to become a DT teacher, so thank you for helping me to improve my electronic knowledge.
Sep 16, 2010. 6:18 PMsuenami says:
they make super brights without the need for a resistor in the circuit now? sorry, it's been a while since I did stuff like this.
Sep 26, 2010. 10:53 AMLhtrf says:
that was probably a pair of 1.5v batteries, and since leds run on 3.4v they would be underpowered, so no need for a resistor. (not all, but most colors do, i dont know about super brights, maybe they are 6v, so in that case i suppose he could have used 6v)
Sep 9, 2010. 7:07 PMdscotthep says:
Very cool project!
One suggestion: ground the LEDs to the metal case and eliminate the negative wiring.
Sep 16, 2010. 12:10 PMPhoghat says:
A so, very wise. I bet you work on cars.
Sep 17, 2010. 6:04 AMdscotthep says:
No, not cars. I do dabble in homebrew amateur radio...
Sep 16, 2010. 8:10 PMPheelix says:
Thanks for the idea! I made one today and will refine my next one. I used my spark wheel ( after some reshaping ) to hold down the switch. Think I will be giving it to my son... that'll freak his mom out.
Sep 16, 2010. 3:51 PMshizumadrive says:
I like the side switch where the spark wheel used to be. The bottom of the case not so much.
Sep 16, 2010. 8:14 AMrbormann says:
Gee, I see a Zippo shortage on the market very soon...
Sep 9, 2010. 7:27 PMrpc24018 says:
Very Cool!
I wonder if there is a way to incorporate a switch into the lid. So when the lid is open the light turns on. Hmmmm
Sep 12, 2010. 8:59 AMxfirexstarzx says:
look at the comment above yours. Use a normally closed reed switch inside the lighter insert and put a small magnet in the lid. When you open the lid and move the magnet away, the light comes on.
Sep 9, 2010. 11:04 PMGeeoff. says:
Maybe you could use a larger switch, cut the plastic so that it's at a slant and when the lid is closed it pushes the switch in(Like the way a door handle works) and then just wire it backwards?
Don't know if that made any sense or if it's feasible, but it's an idea.
Sep 13, 2010. 5:28 PMberky93 says:
you cant simply wire a switch backwards. However, you can get a switch labeled NC or NCL which means "normally closed." Basically most switches are open circuits and pressing them completes the circuit, but with these switches they are normally completed and pressing them breaks the circuit. Perfect for, say, lights that open when a lid is opened.
Sep 9, 2010. 7:56 PMNoseyNick says:
A Zippo for non-smokers! I want one! :-)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:Boyscout201
Hello my name is Richard. I like to take things apart and make them better. My latest builds : Chronulator with Blue LED meters (Instructable coming). Hardwired LED tailgate light strip.
