A short time ago a friend asked me about the 50 watt solar panel they sell at H.F. That's not much power and running it through an inverter would just be silly. So I started trying to come up with something useful enough to justify the purchase.
I found an LED that puts out 420 lumins and only uses 5 watts. (this LED is only 20 bucks)
This is just enough light for a nice bedside lamp ,  and at only 5watts you could run ten of them off a 50 watt solar panel.
That's about as much light as a 40 watt light bulb .  If you had ten 40 watt bulbs in your house and you replaced them with these you'd save 350 watts (that's a lot of watts).
If you'd like to build a few just follow this instructable.  And remember ,  stay safe ,  have fun ,  and every dollar you save doing something green is a dollar that can be put back into the economy some where else to help make it strong again.
Go Green for the Green !!!
Step 1: Stuff you'll need
Your going to need a nice little lamp and a socket that will except this LED (pm me for link)
00MrNotWrong00 (author) says: Jul 19, 2010. 11:54 AM
(removed by author or community request)
00MrNotWrong00 (author) says: Jul 19, 2010. 11:57 AM
Oh I know but I can't change it because , The server had a problem! Please try again in a few moments or reload the entire page. The server had a problem! Please try again in a few moments or reload the entire page. The server had a problem! Please try again in a few moments or reload the entire page. The server had a problem! Please try again in a few moments or reload the entire page. The server had a problem! Please try again in a few moments or reload the entire page. The server had a problem! Please try again in a few moments or reload the entire page. The server had a problem! Please try again in a few moments or reload the entire page. The server had a problem! Please try again in a few moments or reload the entire page. The server had a problem! Please try again in a few moments or reload the entire page. The server had a problem! Please try again in a few moments or reload the entire page. "Help" someone fix this server.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
