loading
Step 3: Step 3
anchoring the LEDs on the spokes of duct tape and clamps
anchoring the battery on the sleeve and collar tape
connect the LEDs to the battery
<p>IS resistors necessary? cos the material list didn't include resistors</p>
<p>very good this helps me alot ......but i m facing batery problm </p>
<p>I wonder what it would look like with UV LEDs with spokes and inside of rim painted with fluorescent paint.</p><p>Nice work. I suggest for the beginner to include a schematic diagram.</p>
<p>yes..!!! it does form a circle..!!!</p>
<p>i would like to know how u connected all LEDs to the 9 volt battery?i have used 5mm LEDs when i turn the wheels it doesnt show smooth circle like yours..please help me..</p>
<p>i made it..but it just doesnt form a circle..each LED is connected to battery with a resistor of 470 ohms(yellow violet brown) to a 9 volt battery.</p>
<p>this is quiet simple and much more less expensive. I'd like to try this out on my motorcycle. </p><p>Quick question though, how about using the hamster wheel principle in making the LED lights turn on as the wheels are moving. That would save us from buying batteries too.</p>
<p>Spectacular!</p>
<p>you can use google translate, which translates directly to English text with perfect spelling.</p>
sorry for noob question.. how should i wire the LEDs? 4 LED in series = 9V battery? and then another set of these again? should i make it (4 LED in series) parallel with (4LED in series) = 9v battery?
Hi! I'm from Ukraine)))<br><br>Why not to drill the holes in the rim and hide all wires inside?<br>Battery will be hidden near the hub
Wouldn't this weaken the wheel?
Not at all the spokes are really what keep the wheel straight and strong
Understood, but wouldn't an unbalanced weight (the battery pack) cause spoke deformation and ultimately a buckled wheel?
You could drill on to the wheel. <br> <br>Remove the inner tube and the rubber band/liner which is used to prevent the spokes touching the tube. <br>Drill your holes at the required position around the wheel. Do this from the outside, in. Ensure that you have one extra hole, which will be used to allow the wires to come out of, you need to decide where this should go, but it should be close to one of the LED holes. <br>Clean the holes of any burrs. <br>Insert the LED through the hole from the outside, so it faces in, checking the polarity of the LEDs so that the positives of the LEDs are all on the same side of the wheel. <br>Use some silicone sealant around each LED, on the side that the LED legs are. This will hold it in place and prevent water getting inside the tyre. <br>Crop the legs of the LEDs, so that they are about 3mm long then bend them over so they are parallel to the wheel. <br>Solder a red wire to the positive side of the first LED and carry on connecting up to the next positive leg until all of the LEDs are connected, laying the cable in the rim, where the rubber band was. The rubber band will then cover the wires. Repeat this for the negative side. <br>On the last LED, connect enough length of wire to come out the extra hole drilled for the wire as it will go up the spokes towards the wheel hub. The wheel hub is where the switch and battery pack can be mounted. <br>Insulate the solder joins with some insulating tape. <br>Test that the circuit works. <br>If it does, then refit the rubber band/liner tyre and inner tube. <br> <br>You should be all set to looks uber awesome. <br> <br>
I think drilling holes into a bicycle rim would be quite a bad idea. The rims are kept in tension by the tensioned spokes, and have to withstand all sorts of stresses from the road, pedalling, and braking, so you wouldn&rsquo;t want to weaken them with holes which which would be a good way for cracks to develop from.
Nice idea but you would have to make the holes with leds airtight
Erm, no you wouldn't. The air pressure is in the tube not the tire. You could keep it water (and air) tight with a bit of silicone though, which would probably be a good idea.
Doh, too much time dealing with car tyres.
I like ur idea
But the entire set-up will get damaged when it rains right?
I think you can connect directly to the negative pole of the rims as a grounding, so it can have fewer cables. CMIIW :)
This could certainly work, provided that you can make a secure electrical connection from each LED negative to the wheel and also one for the wire to battery.
Are the led's in series? and also i tried using 4 led's and hooking it up to a 9 volt battery and it shorted.. Should i use more led's? or should i use capacitors? Please reply asap.. Need it for my bike :) Props bruh! :)) God Bless! :D <br> <br>Btw.. Im using 3 volt led's
4 LEDs in series, if each is 3V. 4 * 3V = 12V <br>No need for capacitors. <br> <br>Please check the polarity (which way around) you connect the LED to the battery, if wrong, the LED with not power up.
I think this photo can help you, this is a scheme of bicycle wheel light.
Can you make these into kits for sale?
Certainly <br>:)
Great simple image. <br>This would work for standard LEDs with a Vf of 1.5V. <br> <br>Anyone wanting to run off 12V, then you could use 8 LEDs (8*1.5V=12V) <br> <br>In the parts list, the author mentions that he uses 12V LEDs. These essentially have a bias resistor already built in.
But i dont see the cables in that position.. do you think the led's are connected directly to the switch then the switch is connected to the battery? Please reply asap :) Thanks!
So where can you get these tiny blue LED lights at? I plan on starting this project soon.
Any place that sells electronic devices. <br>Search Ebay for 12V LEDs for example.
Nice project! But I have a question: if you don't use a resistor, then what will limit the current flowing through the LEDs? Because LEDs usually fry when you wire them up directly to a battery :D
Muromec is using 12V special LEDs. Imagine each LED with a limit resistor already built in. <br>If you can not get these type, then regular LEDs that have a Vf, forward voltage, of around 1.5 would work but you would need to add a resistor if your wired them in parallel. <br>Wiring in parallel, meaning each LED + goes to +V through the resistor and each LED - goes to -V. The down side to this is you waste more power as each bias resistor is used to drop the voltage from 12V to 1.5V, not efficient way, the battery life would be lower. <br> <br>You could wire the LEDs in series, ie the first LED + to +V, the first LED - to + of the next LED, so on etc until LED #8, then the - of the LED connect to -V. In series, the sum of all Vf should match the input supply, so in this case 8*1.5V=12V. <br>The down side to this is, if one of the LEDs fail, the whole string fails, however, the total power would be lower than parallel mode. <br> <br>The drive circuit could be improved by using a small regulator circuit.
1 LED- 12V <br> 5 LED - 60V <br>1 battery - 9V <br>How you get these 60V on the one circle?And how long all this works?
Also note, as 9V battery is being used, then you will not be running the LEDs at full power/brightness. You could wire 6 AA batteries in series to get 12V thus making the LEDs brighter.
** 8 AA batteries
This type of LED runs on 1.5volts, not 12V.<br>Just thought I would mention that.<br>
No. Each LED runs on 12V max. But muromec connects them in parallel, not in series. So in his case each LED runs on 9V from the battery.
thx for an answer : ) <br>
Great Instructable
I would love to do this, but I live in an area where it rains somewhat frequently. Any suggestions on waterproofing this system?
LED's are waterproof. Worry about the switch.
Try using an LED light strip. Here's a red one on eBay: http://www.ebay.com/itm/Red-WaterProof-5M-16FT-SMD-3528-LED-Strips-300-lights-leds-60-Leds-Meter-Auto-/110746899925?pt=US_Car_Lighting&amp;hash=item19c90795d5#ht_5925wt_868
Thanks, I'll check those out.
Phenomenal for safety! This should be the new law. <br />
This is coOoL.. Looks like a tron light cycle!
AAAAAAAAAAANNNDDDD I want to this to a frisbee. How cool would that be, A tron frisbee.
nice one!<br>i would love to do this on a car.<br>all i would want to do is figure out how to get it to turn on without having to do it manually.
See this post, where do on car http://www.drive2.ru/cars/toyota/will_vs/will_vs/sanekvs/journal/288230376151744259/
About This Instructable
112,203views
329favorites
License:
More by muromec:LED logo Rammstein on  bicycle LED bicycle wheels Jason mask Friday 13.
Add instructable to:
