Introduction: LED Bottlecap
Light up your party drinks/sodas for special effect.
I was thinking of something special and new to do with LED's this afternoon and came up with this.
Step 1: What You'll Need
****What you'll need***
-Bottlecap
-LED(white) with button batteries and battery holder
(i took mine out of a lighter i bought for less than a 1$)
-some wire
***tools you'll need***
-soldering gear
-scissors
-screwdriver
-hot glue gun
-cutting knife
Have fun making... :D
Step 2: Taking Apart the Lighter
(removing the LED flashlight from the lighter)
**Tools required for this step:
-Screwdriver
--The backplate of the lighter easily comes off by removing the small screwdriver.
But removing the flashlight was harder and i had to break ot out using the screwdriver.
Step 3: Modifying the Battery Holder
**Tools needed for this step:
-cutting knife
-glue gun
-wire
-pliers
--Since the battery holder is way too long to fit into the bottlecap, i had to cut one battery section off and stick it to the side of the other two as shown in the picture.
--first i took out the batteries
--then i cut one of the sections off
--i used the glue gun to stick the section onto the side
--add the batteries and connect the relocated one to the other two with wires as shown in the picture, make sure to get the polarity right.
Step 4: Finishing Off
**tools needed for this step:
-hot glue gun
-cutting knife
-patience
--The bottle caps i have have a thin low 'second wall' which you can see in the pictures
I used the cutting knife to cut thin slits in it for the two wires to pass through.
--the wires are posititoned such that when the bottlecap is screwed onto the bottle, the edge of the bottle pushes the two wires together closing the circuit, when the bottle is screwed off the elasticity of the top wire separates the two, turningt the light on.
--the mechanism isn't perfect but works, but im open to suggestions and improvements.
Step 5: Product Photos
Hope you have fun making it!!!:D
27 Comments
Do you want to illuminate your active drinking bottles or do you want to turn original bottles into lamps?
If so, the second choice, then use some non-conductive fluids instead, like some coloured vegetable oil or something. This will also prevent any shorting of the electrical part.
Does it stop working if it gets wet?
Also, id recommend covering the whole mechanism with the hot glue gun and make it waterproof. Leave only the 2 wires that are used as the switch uncovered to keep them functioning.
Very cool video. But you dont have to ruin the lighter for the led. If you press the button hard enough, you will be able to take it out without breaking the lighter plastic. Thats how i do it. Also, can you tell me what music did you use for the vid? :D
Very cool, What happens when the liquid moves around and splashes on the light?
You should probably try to put some plastic around it. Maybe making the bottle cap a bit larger , so you can put the batteries and the led further back so you can put plastic circle or something in front of it.
Seriously, what kind of lighter has a built in LED and battery?
well the ones i can buy in the country i live in have...and they are super cheap, like 20c
Really? A coin cell costs like $3 at my country.
a cell costs 12c in my country
