3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED diffusion
LED diffusion
LED diffusion
For better LED diffusion J have paint the led in white color,this is very simple but
useful.
Step 1Paint the led
Paint the led
Paint the led with brush in white color and after is dry,the led you can use it for something you want to light with diffusion.
26 comments
Feb 3, 2009. 10:53 AMadmin says:
Hello, and welcome to the Instructables community! It's great that you've decided to tell the world about something you've made by publishing an Instructable. We just wanted to let you know that your project still needs a little more work if you want it to be well received on Instructables. Projects that don't include certain basic elements tend not to get the attention that they deserve, and so we'd love for you to check out the list below of what makes a successful Instructable. Successful projects on Instructables include: - clearly written details of a finished project with instruction - as many steps as are necessary to explain your project - clear images that you took of your project for most, if not all of your steps - an intro image - proper spelling and grammar - appropriate cautions or safety considerations I'll give you another opportunity to make any final changes to your project before we publish it. Once you're all set to go, please republish your project and send me a quick comment letting me know that you've made some changes. I'll give it a quick final check to make sure you're on the right path, and then remove this note. Thanks for your submission and we hope to see your project published soon!
Jan 24, 2011. 9:47 PMusLEDsupply says:
there are lots of ways to diffuse a led (sanding, covering with glue, grinding, sticking it in a ping pong ball, etc...) but in doing so you are reducing the output sometimes to almost nothing:-( if you are looking for a nice even light without hot spots get some 3528 or 5060 SMD leds (you can find them in 12v strips or 12v mini modules or you can even get them individuality but you will need to take care to provide the correct power in that case) either way if you want a nice even light you can't beat them
if you are looking for a spot then go with a polished led or one with a reflector or lens
Dec 28, 2010. 5:33 PMtinkerunique says:
May be overkill but for "mood lighting in my truck I added a resistor, and went over the LED's with a wire wheel on my Dremel, THEN notched a "V" in the top of the lens to eliminate the focus & spread out the light pattern more. Mounted out of sight under the dash, the floor lit up without the 4 blue spots earlier on the floor.
Sep 20, 2010. 9:46 AMkadris3 says:
another way of diffusing an led is 600 grit sandpaper on the end of the lense. do three swipes in one direction, then turn the led 90 degrees and give it three more swipes. repeat if necessary. unclecytheledguy.
Jun 27, 2009. 4:29 PMhapman9 says:
ok im new so what exactly does defusion do??/??????
Jan 20, 2010. 5:34 AMzeroemission says:
DIFFUSION basically means "scattering light" eg. the diffused light on a cloudy day prevents shadows.
Apr 27, 2010. 11:34 AMThe Ideanator says:
"the diffused light on a cloudy day prevents shadows."
Uhh, I hate to interrupt, but there are shadows on cloudy days, they're just less apparent because the light isn't as directed as on sunny days.
Apr 28, 2010. 12:45 AMzeroemission says:
um, i hate to interrupt you, but you just DEFINED diffused, and on a TRULY cloudy day, which you might not get where you're from, you really DON'T get shadows because the light is so diffused you can't even tell where the sun is so basically, everything is lit from all directions. the entire sky becomes one evenly lit overhead light. sure, if you hold your hand 1/4" off the ground there will be a shadow under your hand, but standing up, you will not see your body casting a shadow.
there's a difference between "some light clouds in the sky" and a TRULY dense cloudy day in a low elevation. i grew up in central new york where you rarely see patches of blue sky and even when you do, it's a dull blue/grey. when it gets cloudy there, the light really does get diffused.
Feb 2, 2010. 6:57 PMkikiclint says:
sanding the led will make it diffuse as well, as well as let more light through.  You could even sand it into different shapes.
Apr 27, 2010. 11:30 AMThe Ideanator says:
I was just about to say that.
Mar 26, 2010. 9:35 PMArticas says:
i notice your following ohms law with that resistor
Feb 8, 2010. 11:42 AMeyerobot says:
A round blob of glue from a glue gun on the tip of an LED,  achieves the same effect.  The problem is that any diffusion of light will show you just how weak these LED's are.
I was thinking of using multiple LED's aimed at one diffuser, Such as the hot glue blob, Or some sort of crystal.  The idea being to eventually replace incandescant lights, With something equally as strong, And that has a wide dispersal angle.
But im also at the mercy of mail order shipping schedules, Before I can attempt this further.
Throw some painting techniques in this instructible, And that help message should vanish.  Good idea though.
Dec 16, 2009. 8:42 PMHe11uvaCook says:
Why not use a (few) thin coat(s) of white-out??  Seems like it would allow you to apply as much as needed to diffuse the light as necessary.
Jan 20, 2010. 5:33 AMzeroemission says:
people have used glues like superglue to diffuse light through plastics too. i used the sandpaper technique on the bezel of a bike tail light too, but it would be harder on LEDs.
Jan 5, 2010. 12:15 PMinlikeflint says:
Great idea... Standard household lightbulbs have some sort of white paint like sustance on the inside of the bulb. I am off to look for semi- transparent spray paint now.
Oct 16, 2009. 6:27 AMand-reas says:
Very good idea! I'm gonna use this in a ledcube or someting for sure.
What kind of paint did you use?
Jul 7, 2009. 6:20 PMhammy10809 says:
you could just dip it in the paint
May 25, 2009. 10:39 PMnotveryreal says:
Pretty good idea.
May 9, 2009. 9:12 PMs1 says:
Fine grade (2000 grit) wet and dry carborundum paper works extremely well, causes almost no loss of light output. Less work but harmful to environment, dip the water-clear LED in MEK , quickly withdraw and allow to dry.
May 7, 2009. 8:30 PMSoksume says:
I find sanding with a fine grit sandpaper like 400 grit works wonderfully
Apr 27, 2009. 4:42 PMel triste13 says:
i just bought them on ebay 100 for $10yeah but its only five colors
Apr 19, 2009. 10:33 AMsandos says:
I think one downside to this approach is efficiency, if you care about that: the paint will likely block most of the light output! Still a nice simple idea. Ive tried sanding 5mm LEDs to diffuse them, and that didn't really work too well.
Mar 30, 2009. 5:24 AMnidobrito says:
Awesome!XD
Mar 22, 2009. 12:32 PMsweetnes22 says:
Thats a great idea ive been looking for a way to do this for months but i havent found a good way untill now =)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
35
Author:macobt
