The band's name is 'les josettes noires'. They're a girl's fanfare based in Paris.
You can listen to some of their covers here:
http://www.myspace.com/lesjosettesnoiresfanfare
You can also become a fan on Facebook:
http://www.facebook.com/pages/les-josettes-noires/15202648335
Now, let's get on with the making...
You'll need:
- a sousaphone
- 150+ LEDs (8 per letter)
- a battery (we took 3x(4x1.5V) rechargeable ones in serie.
- as many resistors (the right ones) as you have letters
- Someone good with numbers to tell you the type of resistors and battery you need
- thick (10mm) white foam board
- thin (4mm) black foam board
- a switch
- a stripe of fabric for the outside if you want
- double sided tape
- cutter
- a thick needle
- soldering iron + solder
- wire
- a sunday afternoon
- a girl's fanfarre
Remove these ads by
Signing UpStep 1Get cutting
Print the letters again. Double side-tape them on the black foam board. Cut them.
Now on the back side of the ring, mark with a needle the corners of the letters. Go all the way through the thick foam board. That way, you can see where to place the letters so they fit evenly, as you had planed on Illustrator.
Use double-sided tape again to fix the letters where they belong.
Congratulations
