hello all, heres an attempt i made at something like an LED throwie..
the problem (for me) with led throwies is that they just consume their battery, and produce light.. but they could be better at doing both..
first you have to accept the premise that your willing to spend a bit more for the tradeoff..
the inspiration for this came from some of my other projects, and of course the "LED as a sensor" concept as well as the "LED throwie"
so the parts list:
1 common cathode, tri-color (RGB) LED
1 12f683 pic micro
1 coin cell battery holder
(cheap plug) http://www.makenyc.org/
Remove these ads by
Signing UpStep 1So whats it do?
the software is designed to use the LED as a light sensor (so as not to waste power during the day)
the led as an entropy source (to make each firefly unique moments after switching it on) to vary blink color, and rate.
and of course to play a flash pattern every so often in a way that seems "organic" and isnt just an "on/off" blink
and of course use as little power as possible!
(apologies for the darkness of the video, but the light had to be dim enough not to trip the fireflies daylight sensor)
http://www.tvbgone.com/cfe_tvbg_main.php
Basically just have to mod it a little and put a magnet on it
im also not sure if *every* tv remote operates at 40khz
another question would be if the "led as a sensor" with an ifared LED (the black ones) would also work as an infared sensor..
i'm still trying to figure out if i can use the RGB led as a color sensor
http://www.instructables.com/id/Programmable-LED/
same-same, but different
always good to read around a topic
http://www.instructables.com/id/Synchronizing-Fireflies/
might help with the synchronizing effect you're looking for...
http://www.ladyada.net/make/tvbgone/
The source code is available free for download.
The codes for a bunch of TV brands are included in the source.
You know you could build onto this with a solar cell and the simple circuitry of a resistor, a 3904 and a 3906 transistor and a capacitor and wire it onto the power part of the chip and you have a self contained unit.
I reeeallyy want to build one of these, but I know my local radio shack doesn't have these sort of parts. Its going to be hard to order things online for something with this build, but I'm sure I can find a friend to help.
With the idea I have, encasing the while thing in acrylic would seal it permanently and then you would have something cool forever.
You have my fave on this one for sure.
