3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED flashlight for under $10 (solderless, flat)
This Instructable will show one how to build a LED flashlight without solder that will lay flat for under $10. The idea for this came from a need to have a flat flashlight that would not roll around when I was working on computers and wiring for my tech support business. Also, I needed something that could be inserted into narrow places, like behind furniture and inside computers. Since I could not find any flashlights that would be able to do these things, I decided to imitate the Free Software/Instructable Communities and build one to my specifications. For the construction of the circuit, many of ideas came from other LED flashlight Instructables on this site. A basic schematic is below.
Step 1Assemble your parts and tools
Many of these parts can be found at Home Depot, Radio Shack and 99 Cents stores.
Parts from Home Depot:
1. One foot of Cat 5 cable (split for 20 gauge wire), Part #: 709489: 27 cents
2. Wood shims, Part #: 091-996-002-0000: $1.09
4. Electrical Tape, Part #: 0-775-78-03-777-6, 59 cents:
5. Light switch, Part #: 078-477-772-713: 64 cents
Parts from Radio Shack:
1. two - 5 mm high brightness white LED, Part #: 276-017: $1.99
2. AAA Battery Holder, Part #: 270-398: 99 cents
Part from Jack's 99 Cent Store, 32nd St. between 6th & 7th Ave, NYC:
1. 2 AAA Batteries: 99 cents
2. One 8.5x11 piece of paper: 1 cent
Tools:
1. #2 Phillips head screwdriver
2. Wire cutter/stripper
3. Scissors
LED-Flashlight.pdf(794x842) 90 KB
9 comments
Feb 16, 2012. 7:51 PMjsilvers1 says:
i wonder if u could add a solar panel to this to charge the battery and still have the on/off switch so that u can turn the light when u don't need to use it
Jun 13, 2009. 8:54 PMmarc92 says:
I believe it would be possible to make this light much smaller to better fit in the places described.
Jun 14, 2009. 1:42 PMATG says:
if 3v button cells r used in serie...this thng can fit into a matchbox...
Jun 14, 2009. 1:52 PMmarc92 says:
With the obvious exception of the light switch
Jun 13, 2009. 10:42 PMChiana_Rei says:
This could be done smaller very easily, with junk computer parts, or just other electronic junk one accumulates. The switch you are using will cause more battery run down than a much smaller switch better suited to the amount of current you need to run an LED.
Nov 1, 2009. 7:00 AMlifelong-newbie says:
Radio shack definitely sell the simple parts that'd make this project much more efficient
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:matt392
