LED flashlight for under $10 (solderless, flat)
 by matt392
This Instructable will show one how to build a LED flashlight without solder that will lay flat for under $10. The idea for this came from a need to have a flat flashlight that would not roll around when I was working on computers and wiring for my tech support business. Also, I needed something that could be inserted into narrow places, like behind furniture and inside computers. Since I could not find any flashlights that would be able to do these things, I decided to imitate the Free Software/Instructable Communities and build one to my specifications. For the construction of the circuit, many of ideas came from other LED flashlight Instructables on this site. A basic schematic is below.
Step 1: Assemble your parts and tools
Many of these parts can be found at Home Depot, Radio Shack and 99 Cents stores.
Parts from Home Depot:
1. One foot of Cat 5 cable (split for 20 gauge wire), Part #: 709489: 27 cents
2. Wood shims, Part #: 091-996-002-0000: $1.09
4. Electrical Tape, Part #: 0-775-78-03-777-6, 59 cents:
5. Light switch, Part #: 078-477-772-713: 64 cents
Parts from Radio Shack:
1. two - 5 mm high brightness white LED, Part #: 276-017: $1.99
2. AAA Battery Holder, Part #: 270-398: 99 cents
Part from Jack's 99 Cent Store, 32nd St. between 6th & 7th Ave, NYC:
1. 2 AAA Batteries: 99 cents
2. One 8.5x11 piece of paper: 1 cent
Tools:
1. #2 Phillips head screwdriver
2. Wire cutter/stripper
3. Scissors
LED-Flashlight.pdf(794x842) 90 KB
kurtnotkirk says: Feb 8, 2013. 8:42 AM
Hi, I just posted a question, looking for help with just such a project as this. If I understand this instructable, I can just get the LEDs, as you have used here, and wire them into the existing AAA circuit, without any sort of resistor? Thanks!
jsilvers1 says: Feb 16, 2012. 7:51 PM
i wonder if u could add a solar panel to this to charge the battery and still have the on/off switch so that u can turn the light when u don't need to use it
marc92 says: Jun 13, 2009. 8:54 PM
I believe it would be possible to make this light much smaller to better fit in the places described.
matt392 (author) in reply to marc92Jun 14, 2009. 3:53 PM
The size makes it easier to position since something smaller might get dropped into crevices and the like.
ATG in reply to marc92Jun 14, 2009. 1:42 PM
if 3v button cells r used in serie...this thng can fit into a matchbox...
marc92 in reply to ATGJun 14, 2009. 1:52 PM
With the obvious exception of the light switch
Chiana_Rei in reply to marc92Jun 13, 2009. 10:42 PM
This could be done smaller very easily, with junk computer parts, or just other electronic junk one accumulates. The switch you are using will cause more battery run down than a much smaller switch better suited to the amount of current you need to run an LED.
matt392 (author) in reply to Chiana_ReiJun 14, 2009. 3:37 PM
One of the design goals was to be able to build it with common, inexpensive parts from retails stores like Home Depot and Radio Shack.
lifelong-newbie in reply to matt392Nov 1, 2009. 7:00 AM
Radio shack definitely sell the simple parts that'd make this project much more efficient
matt392 (author) in reply to lifelong-newbieMar 8, 2010. 9:05 PM
Keep in mind, part of the design goal was to keep it under $10.  Radio Shack definitely has good parts, but they may have pushed it above $10.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
