Introduction: LED Light Beat to Music
Picture of LED Light Beat to Music
This project is taking a tip 31 transistor and hooking it up to a led light so that when plugged in will light up to the music that is playing. You'll need a audio spitter that you plug the light in one of the female ports and you audio source into the other female audio port. Then the male audio port you plug into your ipod or whatever device you use to play you music.
get a led light or your transistor
Step 1: Tools and Supplies
Picture of Tools and Supplies
Tools
wire strippers
solder
solder iron
electrical tape
screw driver
Supples
led box
transister 31
wires
2 in one out audio jack
male end audio jack with wire
Step 2: Make It:
Picture of Make It:
solder the ground from the male audio jack to the right pin of T 31. also solder your ground wire to this pin.
solder the postive wire from coming from the battery to the center pin of the T 31.
solder one of the audio out wire from the male audio jack to the right pin on the T 31.
konon2kt (author)2016-03-22
Hahaha I made the same thing in 2012 I think, my first project
About This Instructable
5,394views
47favorites
License:
Bio: I stopped helping people out on hear and sharing my ideas and projects because main stream companies just steal your idea and put it in ... More »
More by buildingandblogging:DIY Happy Gilmore Hockey Stick Putter Spinning Wheel85 Truck Modifications and Counting
Add instructable to:
