loading
Step 7: Place LEDs and resistor in housing
Next, I flipped the housing over placed the LEDs in, aligning them with their holes. I didn't want to press them all the way in yet; just gently seat them in their holes so they stay put. Then I solderd the resistor onto the end.
<p>Nice project, I am thinking about doing something like this under our kitchen cabinets. One thing that I have been worried about is fire hazard. Does anyone know if this could cause a fire, I know LEDs do not emit heat, but still they can get a little warm or even hot. How long can you keep these on for and can you sleep at night peacefully knowing that this will not cause a fire if left ON overnight? </p><p>Can someone knowledgeable address my issue please, I would be forever grateful.</p><p>Thanks,</p><p>Mike.</p>
<p>When I made this, I had a bag of LEDs that had been rejected from a project for being the wrong shade of white but were otherwise fine. At this point, you can buy a pretty decent LED strip from IKEA, and I'm sure there are dozens on amazon. I don't want to discourage you from making something, but I can't promise that nothing could go wrong. </p>
<p>Okay. Thanks.</p><p>Yup, you can buy ready made cabinet lights, etc...but that's not us right? We make custom! But I understand you. I would just like to go a step further and make sure my projects are safe, otherwise what's the point.</p>
kool project. I think for mine, I will plan to put all the LEDs in parallel, that way one dead LED will not knock out the whole string. requires more math but you have a solid project! <br>and use a 120vac-12vdc xfmr from a thrift store to prevent flicker and help w/ safety.
<p>Putting the LEDs all in parallel is a good choice. A 100 ohm resistor every 3 or 4 LEDs will stabilize the current. A 12v wall adapter is the best option here. Using mains voltages is quite dangerous.</p>
<p>Cool project. I'm very interested in blending wood with LED technology. Is there any issue with heat in this application? Others use various heat shields etc.. Thanks!</p>
any action shots available?
don't forget a diode, by exemple : 1n4007 <br> <br>thanks! <br>marC:)
Good instructable, but you shouldn't have soldered them in serie, because if some LED breaks down, all of them are going to turn off. So, you should solder them in pararel.
That's a good point, but I wanted to keep the wiring fairly simple here. To run the LEDs in parallel I'd need a power supply that would source half an amp at a little over 3 volts, and a way to make sure each LED had about the same amount of current flowing through it. You could use a high-power USB charger or something like that for the power source. Depending on the variance in the LEDs you might need a small resistor for each one to make sure you get current through all of them.<br>Cheers.
You should group the LEDs in blocks, like each 4 LEDs in series, and then connect these blocks in parallel, it would make repair easier, because if they are all in series if one breaks down it will be hard to find, especially if you have a 100 or more of them.
You're right.
Nice work... hope it survives the Mains voltage fluctuations, since a resistor has been used instead of a capacitor, which can absorb the shocks better... <br> <br>I have made some LED projects using caps, sensors, etc... incase people are planning to make some... <br> <br>BE EXTRA careful, since you are dealing with AC Mains (both 110V or 220V). <br> <br>reg <br>ketan <br> <br> <br>
I think I saw somewhere where somebody used LEDs on AC by wiring some in both directions. I think it would simply mean you make two circuits similar to this one, but one going the opposite direction. I don't know if that would change the characteristics of the light, but I think it leads to more efficient use of the current. <br> <br> <br>Nice simple project though! Please update us if anything blows up.
You should be able to make a rectifier using 4 LEDs (or normal diodes) and then connect the rest of the LEDs to the rectified voltage. You could also use a center tap transformer and two diodes, or just get a DC supply. I wanted to keep this one simple, but I may do some fancier wiring in version 2. <br>Thanks.
About This Instructable
39,571views
106favorites
License:
More by acosand:LED light strip in wood housing
Add instructable to:
