3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED only apartment lighting
  • last photo ←
My on average power consumption is 100 watts! If I turn on ALL the lights in my apartment I will be consuming 324 watts.
Motivation: saving money on electricity, being energy efficient and doing it on a budget
Scientific data: When a light-emitting diode is forward biased (switched on), electrons are able to recombine with electron holes within the device, releasing energy in the form of photons.
This makes perfect sense to me, but if you're a bit confused read this wikipedia page on Light Emitting Diods http://en.wikipedia.org/wiki/Light-emitting_diode.
LEDs use even less power then Compact fluorescent lamps (http://en.wikipedia.org/wiki/Compact_fluorescent_lamp) and in the recent years the price of these lights have gone done enough to be affordable.
Disadvantages to using LEDs:
   1. They do not emit as much light as regular or CFL light bulbs.
   2. If they do, they cost way to much.
   3. To achieve normal lighting conditions you must use many LEDs
   4. If you use DC power, you must use very thick and costly wiring to
       reduce resistance at low voltages
I looked online and in various stores for LED lights. The most affordable ones seemed to be flood lights with a GU5.3 plug. However, it would take very many of these "bulbs" to produce sufficient light and lots of wiring. But since these worked with 220 Vac (European standard) I would save on wiring.
 My choice LED light bulb consists of 18 small LEDs put together in a hexagonal matrix with a reflator background with a small individual power supply inside each lamp. Thus, it uses regular voltage and each light reduces 220 Vac to 12 Vdc the diods need (pic included).
I bought 10 of these lights in a hardware store and started experimenting with how much light these would give out. It turned out that I was happy with 4 lights per 10 square feet (1 sq meter).
I also had a white string of LED Christmas lights from IKEA, which I wanted to use in the bathroom.
Once I had the lights, I could start planning my lighting with LEDs.
Step 1Plannig
Plannig
My apartment is 516 square feet (48 sq. meters - 8 x 6 meters) 26 x 20 feet (I'm including a photo with detailed dimensions, although in Russian and metric). One studio/room and a bathroom.
I figured to grid the ceiling in 1.6 x 1.6 in  (50 x 50 cm) squares and put the LEDs in intersections. I needed 135 LEDs.
I looked online and in various stores. I found the best deal in Moscow, Russia to be at LED-LAZAR http://led.promzone.ru/service.htm – a manufactured of LEDs in small town of Serpukhov (http://en.wikipedia.org/wiki/Serpukhov), outside of Moscow.
For the LED - G5.3- 220 whites I paid 70 Russian Rubles which is roughly $2.50
I also bought 20 of the improved/higher luminosity LED-G5.3-6UW-C at 80 Russian Rubles per light bulb, which is roughly $2.75
I bought these at wholesale prices since I was getting over 100 light bulbs.
I paid $275 for 130 of the  LED - G5.3- 220 and $55 for the improved  LED-G5.3-6UW-C. I spent roughly $330.00 for all my lights.
I then had to buy the fixtures to install the light bulbs in a fake ceiling made out of drywall. These ran 29 Russian Rubles per fixture, which is about $1.00 I spent another $135.00 for the fixtures to install the LED lights into.
Now I had to buy the wires. Each LED uses 2.4 watts of energy. So If I turned on all 135 lights simultaneously I would be using 135 x 2.4  = 324 watts. And according to Ohm's law, this means that there would be a current running through the wires of (324 watts divided by 220 Vac) 1.5 Amps. I then looked up wire diameter tables online and got 3 times the diameter I needed, which was 1.5  square millimeters.
I purchased 700 feet (200 meters) of this cable at about $150.00
Below is a link to over 20 photos of my lighting setup (in Picasa web albums)
slideshow via picasa
84 comments
1-40 of 84next »
Apr 3, 2012. 4:54 PMdecc1954 says:
To the author of this magnificent instructable.
Thank you for THINKING, and
thank you for sharing this.
I think all of the hoopla merely reflects that you have an impressive instructable.
It is EASY to find fault.
Finding diversity and flexibility and ingenuity would be more productive.
Thanks for this. When can you help me with my place? LOL.
Jan 31, 2012. 5:56 PMgauzz says:
Looks a bit violet but it could be tha camera's white balance setting since a couple photos don't have the violet tone.
Jun 19, 2011. 10:22 AMSDdiy says:
I am really curious about the details and what products you used. I am assuming somewhere you had to use a power brick or some sort of converter to step down the power going from your power service into the lighting systems. Did you use something custom or just a generic power block that comes with an under cabinet lighting system?
I want to do something like this in our laundry room with exposed ceiling. Not being an electrical engineer I was hoping to be able to use an under cabinet modular system and tie it into the existing wiring.
Jun 19, 2011. 7:59 PMHiFiMan says:
It takes a transformer to raise or lower voltage.A diode rectifies AC to DC and the capacitor smooths the pulses out of the DC voltage.The diodes and capacitors have little effect on voltage manipulation other than minute parasitic voltage drops.
Usually placing 3 LED'S in series will allow them to be powered with 12volts using a current controlling resistor,12 volts seems to be the preferred voltage set up since this allows the user to switch to battery power in case of power outage.If you plan to power many LED'S then I would recommend using a current regulator such as a LM317 or larger current controlling package. LED'S can be powered by low voltage AC as well.
To all those interested in a project like this I suggest NOT using typical dome type LED'S, as these are not designed for lighting applications but rather for indicator applications.The sm5050 is a good choice for low power consumption use at low cost but you will need to use several in a series parallel configuration.
LED'S are available in many wattage's now for lighting applications from less than 1 watt to over 10watt each.
Jan 2, 2012. 3:34 PMac-dc says:
These are set up with a current regulating switching power supply. No transformer is likely to have been used as they aren't needing to achieve a precise voltage, rather a switching pulsed high frequency output through an inductor which ends up as an average current tolerable by the LED and a frequency high enough the human eye cannot detect it.
Here is the big design choice. You can opt for modularized "bulbs" each with their own step down rectified power supplies in them, leveraging existing bulb sockets available for a mains 110VAC or 220VAC system, or for various ways to drop current on a 12VAC or DC system, OR you can do it from scratch with the emitters, custom housings, and a single or fewer (think I'd want more than one so A single point failure does not cause loss of all light everywhere) centralized power supply.
Generally the centralized supply will be more power efficient and "can" cost less in total if you are skilled enough to fabricate your own light housings, but it will be much less user/homeowner/etc friendly for someone else to deal with later which is a very good reason to avoid that kind of setup for permanent residential lighting where average people have to deal with problems later opposed to specialized industrial situations or portable and/or disposable lighting devices.
On the other hand if you were to use a centralized supply with fancier circuit including active PFC, your power factor could be very close to 1 so measurements and conclusions about power usage were more precise.
Jul 27, 2011. 7:09 PMpfred2 says:
LM317s are linear regulators and being such they dump excess voltage as heat. The further you need to drop from input to output the worse it is too. As much as I may like linear regulators efficiency isn't really their strong suit. A better choice would be a switching supply like we use in our computers.
I powered a regular dome LED once with some diodes and a resistor to use as an indicator light in a project I built and was amazed how much power I had to dump to get an LED to work off wall power. I think I used a 5 watt 2200 ohm wire wound resistor and the thing got hot enough to cook on! Calculating it I could have even gotten away using a 2 watt resistor. The 5 watt one I used was almost getting too warm for my liking though so I stuck with it.
It worked out OK replacing a burnt out neon grain bulb I didn't happen to have another on hand to replace it with. But I'm sure it is a massive waste of power.
It is on the right side of the tan box with the black stripe on it in this picture where I'm wasting another 100 watts of power load testing a linear supply I'd built:
http://img196.imageshack.us/img196/6414/pict0576h.jpg
I was so mad because I'd already cut that case out for that particular indicator lamp then the neon bulb burnt out! All the circuitry for the LED is inside that metal case. I built it on an old lug strip.
For the curious:
http://img713.imageshack.us/img713/2244/pict0579s.jpg
The insides of that linear supply. It is LM723 based adjustable current limit variable voltage with 3 TO-3 boost transistors. Sorry I never did take a picture of what is inside the tan box. Well, this is one thing in there:
http://i.imgur.com/RJS8T.jpg
The rest is a number of block bridges to rectify outputs and a custom barrier block I made to connect everything together. Mostly it looks like a rat made a nest out of wire though.
Jul 27, 2011. 6:21 PMpfred2 says:
So with your total watts consumed figure you've actually used an ammeter on the AC power input to measure this or did you just add up the rating of all your LED lights?
Nov 12, 2011. 4:47 AMpfred2 says:
I'm glad you have absolute faith in your instrumentation. Having been exposed somewhat to the complexities of power factoring AC current myself let me just say I've my doubts.
The only way you could test the two for me would be to use the same method for both loads. Anything else is apples and oranges I'm afraid.
I'm sure you're saving power, I'm not so sure you know exactly how much power you are saving though. Because actually figuring that out isn't trivial. Well, it isn't for all us folks who can't count every electron flowing past a point. ha ha!
Jul 28, 2011. 7:28 PMpfred2 says:
What model? I'd like to see such a device that has a gauge that displays its input. That is rare.
Jul 29, 2011. 3:31 PMpfred2 says:
I must say it's all Greek or Cyrillic to me? Klingon? Chicken ran though spilled white paint? The correct answer is D All of the above.
Nov 11, 2011. 6:05 PMzilcho says:
Looks Russian
Nov 11, 2011. 8:49 PMpfred2 says:
Same difference.
Jul 1, 2011. 6:50 PMangelosantoz says:
Such a great project! If only more people would do this. The only thing for me is I don't think I could handle such harsh lighting.
Jul 27, 2011. 6:13 PMpfred2 says:
That was what I was thinking. While the overall project is impressive the results I mean the place looks blue! I'd have tried to get a different spectrum LED. Some LEDs do seem to have a rather bluish cast about them to me. But I've seen purer white emitting ones as well.
Jul 28, 2011. 8:05 PMpfred2 says:
Cameras can take photographs with false colors. Noted. It might have been a good idea if you tweaked your photographs digitally just so a lot of us viewers weren't fooled by them.
No I really can't, buy more expensive solutions that is. It does appear to be a growing trend that worries me though.
Actually I find it sort of funny that you even thought I could, or maybe even should. A disturbing trend indeed.
Jul 11, 2011. 9:24 AMstackerjack says:
You can now buy lamps which contain 60 LED elements, and consume less than 5 watts of power.
Search the net for them.
Jun 23, 2011. 5:33 PMBernie_R says:
This is fantastic. I studied "Energy Management" but I live in Chile where energy, until recently was dead cheap. Nobody would listen to my "Crazy" ideas of switching lights off when not in use. Everybody purchased 100Watt incandescent light bulbs as they gave more light! Energy saving bulbs have only recently arrived.
I will try and install your LED idea in my pad and I hope others will follow suit.
Many thanks for a brilliant (no pun intended) idea.
Bernie Robinson
BatucoCity
Chile
Jun 19, 2011. 7:55 AMmarcintosh says:
Thanks for it all. This is just exactly what needs to be done. Someone has to assume responsibility for "Trying New Things" and you've done so admirably. The slide show is HUGE thanks for documenting that so well.
To see if your LED's are wearing or how they're wearing, use a light meter. Good brands are Gossen, Westin, Sekonic, You can find them on eBay really cheaply. You don't need to be worried about how accurate it is as you are only concerned with consistency of the readings.
Thanks again for your work and, for sharing it with the rest of us.
M.
Rich Editor not working right now so it's not the way I'd format it.
Jun 20, 2011. 8:54 AMmarcintosh says:
Using the light meter is better and more definitive. Draw a rudimentary map of your dwelling and include a general placement of the lights, Measure where you stand in relation to the walls, take your light readings, note the date and time for each place you took a reading and write down the light reading off the meter. File that and then do it again the next month. If you are really interested you could put it all into an Excell spreadsheet and track it over time. If not you could just flip the pages to see how things are trending.
g'luck
M
Jun 20, 2011. 5:04 PMguitarman63mm says:
I think a luxmeter would be more appropriate and more accurate. I have a Sekonic L-358 - a great meter for video or photography, but not so great for measuring lux. It gives measurements in EV as well as regular readings, and EV is what you use for intensity. Here is a chart showing conversions for common EV readings.
http://www.sekonic.com/Support/EVLuxFootCandleConversionChart.aspx
You can see how this gets pretty inaccurate with a reading like, say, 5.7 EV. A Luxmeter will give you a more accurate idea. Home interiors are around 5-7 EV, or between 80-320 lux. I just measured my 10x10 room with 120w of incandescent bounced into the ceiling and got EV 3. Obviously, the room is pretty dim. Just some food for thought.
Jun 19, 2011. 2:51 PMml4d3n says:
Hi, i dont think your total power for the entire place is just 100W, there is a lot of LED bulbs, and especialy those downlights. I think that one of them is 2,5W so it must be a little more than that, but never the less, this is a great project, and I, as a power engineer think that everyone can do this as a first step to minimising their bill and saving the world or whatever... I am as well finishing slowly to replace and retrofit all of the lights in the entire house to LED. Just a small concern though - these cool white LED's look great at first but after a while start to look kind of deathlike and cold. They tire the eyes a lot, I recommend using warm white LED's with high color rendering index. They look realy natural.Thank You for this great project, some ideas are very cool, especialy the shower ;)
Jun 19, 2011. 3:17 PMdwosullivan says:
100W for an apartment is totally possible. These bulbs look like the ones made up of 18 or so LED's rather than say a single 2.5W LED. I have a few in our kitchen that draw 0.9w.
For what it is worth our 3 bedroom apartment uses 106W. 2 x 32W circular fluros in living room, 1 x 8W CFL in each bedroom + Bathroom, 1 x 8W CFL downlight and 2 x 0.9W LED downlight in Kitchen.
Great project, especially the shower LED's. How does the shower work? is that 6 pipes for water coming straight down? or will those pipes have small shower heads on them?
Jun 18, 2011. 11:19 PMCeruleanPhoenix says:
Fantastic execution, would love to read more details!
Jun 19, 2011. 7:15 PMgonsena says:
nice work, i will try to do it.
I have 2 questions.
A- how u assemble it, in parallel i suppose so u dont get a blackdown.
B- whats the material u use to put them, in the normal roof and inside the bathroom
C- i got a concrete room that i want to try and a concrete bathroom, can i adapt this by using a false celing or something like that without getting the costs really expensive?
Thank you
Jun 19, 2011. 11:23 PMgonsena says:
nice, thank you, one more question, in the bath flower what u use to diffuse the leds? a plastic or something like that and that's what u made the holes for the water?
Jun 19, 2011. 4:12 PMWragie says:
There are quite a few power sources out there now that you should be able to make work just by adjusting your string length etc. Not that expensive either.
About the only thing I can think of to ask/add is if you used any leds other than the white ones so the light was more daylight in appearance not just the stark blue/white of the white led's?
Anyway nice show of what can be done when you get the chance ie when doing the drywall.
1-40 of 84next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:pashanoid(Paul Tyutin)
I'm a Linux enthusiast, avid diy-er. I work for a company that manufactures "smart" invertors (an Uninterruptable Power Supply for the entire house). I've installed wind generators, solar panels and v...
more »
