3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED panel lamp
LED panel lamp
Well, yesterday I got attack of conscience and decide to make something local to improve world power shortage. I rebuild old halogen 12W lamp in my table lamp on modern LED light.
Step 1Halogen 10W
Halogen 10W
This was reason which push me to work. I have electric power AC220V and it's transformed to plain AC12V which drive this lamp with 1A...o light and heat with 12 W. Very hot!
15 comments
Oct 10, 2011. 11:25 PMmimhs says:
If I connect the half (4 lines X 4 LED's) to use the upper half of AC and the rest 4 X 4 reversed so they use the low transition of the 12v AC I think I can eliminate the use of the bridge diodes .I am wrong ?
Jul 2, 2010. 3:18 AMton2303 says:
This is a nice way of constructing a desk lamp. There is only one small problem with the assumed voltages. If you rectify 12Vac with a Graetz you will get some 16Volts DC on the output. Therefor it would be better in my opinion to have an array of 3x5 LED's. In your lamp right now the LED's are drawing more current than what they are designed for and therefor lifespan will be much shorter. You can use this link to search for the best possible array. Please note there is a single- and a multi LED version http://led.linear1.org/led.wiz Sincerely, Ton
Sep 26, 2010. 1:36 PMhubi says:
This is not right, The peak voltage is ca. 17Volts, but this is the peak, and what counts is the Vrms and this stays at 12V. if you want to get 17VDC you have to add a Cap of a few hundred µF. This also reduces flicker to nearly zero. wtg hubert
May 3, 2010. 3:17 AMbonabono says:
Very nice project , Its what exactily i'd thinking about , But u said u'd connect ur LEDs in series and u used 16 LEDs that mean u need 16x3=48 v , But ur power supply gives u only 12 V , Would u explain that for me cose i wanna convert my desktop lamp to the same , Thx.
Jun 21, 2010. 3:21 PMjules15 says:
there is a lot of amps coming out the secondary side of the transformer.. because of that you can use an LED with 4/10 of a volt because it gets a lot of amps, or milliamps.
Mar 18, 2010. 3:39 AMozoova says:
'Alchoholic' not alcohol based...lol ok ok good tip on to the next step....
Jan 12, 2010. 12:49 PMlemonie says:
That's a very tidy job, nothing much is hidden, and it still looks good.
L
Jan 12, 2010. 8:48 AMDoctor What says:
 That looks cool!  I might have to transform one of my IKEA lamps into one...
Jan 12, 2010. 10:45 AMDoctor What says:
 What if you lined the Plexiglas with a reflective material, say aluminum foil, silver leaf, or something of that nature (like how you covered the back of the LED with silver paint).
Or instead of a flat plexiglass surface, make something with a curve, similar to how a headlight works in your car.  It takes one bulb, and because of the concave reflective surface, it projects the light with stronger intensity.
Jan 12, 2010. 11:13 AMRadBear says:
A buddy of mine used to form plexi by putting it in a tray of sand and heating it in the oven. You might be able to curve the plexi by heating it this way and then laying it over a round form like a pop can.
I've used metal duct repair tape as a reflector in several projects and it worked well.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:KresimirPregernik
