- Adjustable current of 1 mA to 20 mA - Evaluate brightness and efficiency
- Vf (forward voltage drop) measurement - Needed to calculate resistor value
- LED will not be damaged if connected backwards - Voltage is limited to 5 volts
- Power on / open circuit / reverse polarity indicator - Indicates bad or improper connection
Remove these ads by
Signing UpStep 1Parts and Schematic
47 ohm resistor
100 ohm resistor
1 K ohm resistor
1.5 K ohm resistor
2N4401 or similar (2N3904, 2N2222) NPN transistor
Three 1N4148 diodes
Three red LEDs (must be red)
5 K ohm log taper pot
Switch
Transistor socket or similar
Two banana jacks
9 Volt battery clip
Enclosure
Knob (for pot)
Built one following your steps, and it works like a charm, I further enhanced a little bit by tapping two wires onto a small board consists of two rows of turn pins configuration, which screw on with brass pole (insulated the copper board side), so that it could use to test normal led & superflux led as well, thank you again : )
Thanks
i was wondering if you could test laser diodes
I'm going to try this once I manage to get 3x 1N4148 diodes and a transistor socket, whatever that is.
