3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED tilt light box
LED tilt light box
This instructable will show you how to make a simple circuit board with a mercury switch (tilt switch) and LEDs, and then a little wooden box with a window to put it in.
P9020068.AVI(320x240) 15 MB
Step 1Parts needed, and where I got them
Alright so here is the list of materials that are needed for this project, everything can be found at local stores but online is cheaper...
Wooden Box (found at Micheal's arts and crafts)
Project board (I bought at www.besthongkong.com, also at Fry's Electronics)
LEDs (I bought at www.besthongkong.com, also at Fry's Electronics)
Resistors for my project I used 150 ohm resistors, but whichever kind you need for your LEDs, how I have found out is by going to http://led.linear1.org/led.wiz which is a LED calculator, you plug in your information and it tells you the array and what resistors to use. (I bought at www.besthongkong.com, also at Fry's Electronics)
Mercury Switch (found at Fry's Electronics, but I am sure Radio shack has them too)
9V Battery plug (found at Fry's Electronics, but I am sure Radio shack has them too)
9V Battery (found just about everywhere)
Fogged hard plastic (Home depot, Lowe's)
121 comments
1-40 of 121next »
Jan 10, 2011. 2:15 PMmr. bond says:
i used rgbs it looks way cooler.
Apr 2, 2009. 4:02 AMVerathia says:
Mines basically done, but I'm waiting for the 9v battery plug to get here. :) I'll be doing the same thing as you circuit-wise, but instead of a square on the top, I'm cutting out someone's name with a scroll saw. :)
May 5, 2009. 2:32 PMVerathia says:
Actually, I seem to be out of replacement blades for my scroll saw... so I ended up doing this:
http://www.youtube.com/watch?v=k4YsZeHbTRk
The box isn't quite done yet... but I have the basic part of it done.
Apr 24, 2011. 2:47 AMElectrokV says:
A couple of suggestions: 1. ALUMINUM DUCT TAPE TO REFLECT LIGHT (found at most hardware stores) - It can be used for about any LED or lighting project like this. [WARNING: THIS IS METAL AND CAN SHORT ELECTRICAL CIRCUITS! SO, INSTALL IT CAREFULLY AND INSULATE ANY WIRING TO PREVENT IT TOUCHING THE TAPE! THIS IS ESPECIALLY IMPORTANT IN ANY DESIGN THAT USES HIGHER VOLTAGES AND POWER. IT CAN BE A FIRE OR PERSONNEL HAZARD. I RECOMMEND USING SOMETHING LIKE SCOTCH 33+ ELECTRICAL TAPE (600 V / wrap insulating capability) TO INSULATE USUALLY EXPOSED WIRING ANYWHERE NEAR THIS TO REDUCE SHORTING POSSIBILITIES!!!] (You don't want to short out and ruin any circuit anyway) - - -  The idea is to stick the very reflective tape inside boxes like the ones used in this and other experiments behind the LEDs to get more of your light output to shine through the translucent film.  You could just get some construction paper or other non-conducting material and size it to fit the length/width of the box and stick the tape to it and put holes around the LEDs and place it between the circuit board and the LEDs (remembering to insulate the LED leads from the aluminum tape). - - - - I've used this tape in many lighting projects to increase light output and it works fine.
2. I had this in mind before seeing Mr. Bond having the same idea - Experiment by adding more mercury switches and having arrays of various colored LEDs so once the box is upright and on, you can move the box to the other sides and the mercury switches can be setup to turn off one color and turn on another. So, you could have green when the box is on one side, move 90 degrees and it will turn red, move another 90 degrees and it can be blue, and so on.  AND, it's rather easy to break glass mercury switches and the stuff is toxic and almost impossible to clean up, so the switches that use the rolling balls is a good idea!
Sep 15, 2009. 7:20 AMteoeva says:
oh my god, I have this project on my notebook for a year ... and I never realized ... how about applying this concept ... the cube? Put a cube with 5 internal cardboard for 5 different color (the sixth side to switch it off) depending on whose side you will support it a different color ...
Feb 10, 2010. 11:05 AMSaotome says:
heh, weird.
I've been planning to do that exact thing for quite a few months now but never taken the time.
I was thinking about making the cube out of clear acrylic and putting white paper on the inside.
I was gonna use pretty bright LED's (one or two for each color turned toward each side of the cube) and use ping pong balls cut in half to try to disperse the light evenly over the interior surface.
Mar 19, 2009. 3:06 PMpolonium9 says:
can i buy one of your mercury tilt switches?!?!?!!? because i want one for my breadboard experiments and it would be cool to have one
Mar 30, 2009. 7:42 PMpolonium9 says:
the mercury one is not available to order and the other one does not contain mercury but i knew $1.49 was suspicious, lol.
Feb 6, 2009. 7:45 AMDELETED_Negotive00 says:
(removed by author or community request)
Mar 24, 2009. 11:29 PMrosswinky says:
how much is the wooden box and the plastic
Mar 19, 2009. 4:22 PMVerathia says:
I'm extremely new at this so bear with me: Here's probably the first question of many: I can't seem to find an 9v Battery Plug on Fry's website.
Mar 21, 2009. 10:23 PMrosswinky says:
would it be possible to do it so instead of turning of and on it changes colour
Mar 22, 2009. 9:54 PMshamanwhitewolf says:
I would think so. A combo of colors for LEDs and four (or what ever your needs are) mercury switches, each in a different operational position. Turn the box, the currently on mercury switch shuts off and another turns on. You could do a 16-sided box with mercury switches for each side.
Mar 23, 2009. 10:51 PMrosswinky says:
and just have 2 separate circuits? thanks
Mar 24, 2009. 1:56 AMshamanwhitewolf says:
I was thinking of each mercury switch/LED having its own circuit, sharing the power switch and power source. If you have a lot of sides (especially if fully 3D like a dodecahedron), then multiple lights might be on, depending on how the switches are aligned and the position you put the box in. 20-sided light-box dice, anyone??
Mar 24, 2009. 3:02 PMVerathia says:
Ohhh, I want to try a 6 sided box with fogged glass on each side! That would look superb.
Mar 23, 2009. 5:03 PMVerathia says:
I think that would work, but it wouldn't be a smooth fade because the light turn on and off instantaneously. Still sounds fun to try. :)
Apr 2, 2009. 4:30 AMryukyu says:
You can add a capacitor in parallel with the LED and the sinking resistor. That should give you some fade.
Mar 24, 2009. 1:48 AMshamanwhitewolf says:
I didn't think about the smooth fade. That's a good point.
Dec 20, 2008. 2:15 PMjoetcochran says:
Great Instructable - I used all white LED's and cut out some blue and yellow contact paper to make a St. Louis Rams logo. My brother is a big Rams fan, so he'll be getting this for Christmas this year
Jan 9, 2009. 7:12 PMcantthinkof bettername says:
Wow, that looks really nice. Good work.
Jan 9, 2009. 2:43 PMCapt. Fat says:
Now how the heck did you think of that?!
Nov 28, 2008. 5:36 PMguitarist24000 says:
Genius tutorial never knew about this tild switch before usingthis tilt switch i came up with a genius idea.... what if i were to oncorparate this with a wii sensorbar... so i made my own wii sensor bar tht ran off a 9v battery... but heres the big cool part to turn it on your simply tilt it forward... to turn it off you tilt it backwards however im not sure whether i should reveal all the details to the public
Nov 19, 2008. 4:21 PMhumberto_hr says:
hi... how much time do the battery takes to consume?... i think a transistor will make more efficent that isnt?... ty.. great
Oct 26, 2008. 7:22 PMRomaida says:
Great instructable! Do you think I can make this light disc using the same method except without the mercury switch? Any suggestions? Thanks!
Nov 1, 2008. 11:36 AMRomaida says:
The case doesn't need to be round. I could also use your wooden box idea. What size circuit board did you use in this instructable?
Oct 26, 2008. 7:23 PMRomaida says:
Sorry, forgot to add the pics.
1-40 of 121next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
83
Author:seligtobiason(www.SeligTobiason.com)
Well, I feel like I am a pretty regular guy... I work in the Entertainment industry, right now am working for Lucas Animation on a Top secret assignment ;). I love to create things, and build things ...
more »
