Step 2Making the wooden Box
So I marked my cuts with a pencil then used a drill and drilled some holes big enough to fit my little saw blade into. I have a hack saw blade that I used for this, but if you have a jig saw it would be much faster. So just cut out the shape you want on the front of the box, once cut out, don't forget to do a little sanding to make sure everything is looks good!
After the hole is cut out, measure the inside of the box and then mark the dimensions on the Fogged hard plastic. Then proceed to cut out the Plastic so a nice square will fit right into the top of the box. To attache the piece of plastic I used double sided tape, but you can used glue or whatever you choose.
Add Comment
