LED, With Push Button Start and Fade Out
10,405
22
30
Posted in TechnologyLeds
Introduction: LED, With Push Button Start and Fade Out
About: I am, most definitely older than 00010101 and to put it simply, still curious about nearly everything :-) I then tend to read and/or experiment in those areas - when I have the time.. . My two "specialty...
This will describe a simple circuit for allowing a 9 v. battery to power an LED, and then fade out once the pushbutton is released. Something very similar was requested in a question on the forums somewhere. I hope this is useful as a prototype, or in inspiring ideas on how to use this set up.
Step 1: Parts
Here is an inventory of the parts I used:
Q1: most any SS (small signal) NPN transistor will do here.
C1: 100-330 uF electrolytic polarized capacitor
D1: I used a Rainbow flashing LED (so this circuit will flash), if a regular LED is used, it will not flash.
R1: a 10k resistor (carbon, 1/4 w is fine).
For R1, I used a 1 K resistor in series with a 10K potentiometer, for adjustment purposes.
PB: a normally open (N/O) push button switch
Misc.: wire, pc board (or prototype board), 9 v battery snap (and battery), desired case design
Step 2: Assembly.
Here are the steps to complete this project:
Since the schematic is REALLY straightforward, I simply soldered everything in as I had drawn it, except for the PB, the LED, and the Pot.
The PB switch, the LED and the pot., I soldered onto a little extra wire so I could mount them on holes and a slot I had cut into the box. My box was a small cassette style dust cover for backup tapes that were discarded where I work. They make VERY easy to work with cases, and yet are very sturdy.
Looking at the Schematic, and after aquiring my transistor (and consulting a pin out sheet), I found that my transistor was set up (looking at the bottom, with the flat side up) Emitter, base, collector (E, B, C on the schematic). Using a set of hemostats as a heat sink, I soldered in the transistor on one end of the PC board. If you feel uneasy about this, three pin transistor sockets are available from some suppiers (this makes for easy changing of the transistor if need be without soldering).
I ran one wire from the transistor's (E)mitter to the spot on the other end of my PC board that would connect to the ground of the Power supply. To this, I then soldered the negative pin (marked with a - sign) of C1. The positive pin (normally unmarked) was soldered into the board, and then I soldered in R1. R1 was run from the capacitor to the (B)ase of the transistor.
At the joint between R1 and C1, I soldered a wire that would eventually be soldered to one pin of the push button (PB) switch. The other side of that switch (the other pin) was then soldered to the + input from the battery AND to the positive side of the LED. The other pin of the LED is then soldered to another wire that is then soldered to the (C)ollector pin of the transistor.
Step 3: Final Testing and Adjustments
The first time I fired it up, it didn't work. I tried several things....but nothing was lighting the LED.
Then I decided to measure the voltage across the LED and well there's your problem right there!, no voltage across the LED.
Tracing back through the soldering joints, I found one place where there was nearly a hairline break in the solder. Bridging that gap fixed the problem.
Step 4: Let's Box It Up ...
Here I went a bit cheap and found a "non-slip surface pattern to alter for my case (well, the print out of it on paper anyways).
After accentuating certain portions of it, I printed it out, and cut it with a scissors to fit.
I also took and carefully placed a small smear of glue behind each raised bump" (to have it soak into the paper a bit, thus raising that "bump"; making it aesthetically appealing.
It doesn't do much, but it has a lot of potential...IMHO.
Step 5: Addendum: Explanation of Operation.
The NPN transistor needs a signal to the Base to allow electricity to flow from Collector to Emitter, completing the circuit. When the switch is closed, the signal is supplied and the LED comes on. At the same time, C1 is charged, and since DC will not pass through C1, a potential is stored. When the switch is released, R1 slows the drain of C1 (turning on the transistor) and so with a bit higher resistance, the LED stays on a bit longer. This is true, up to a point. If R1 is TOO high, a great enough signal will not get to the transistor to turn on the LED, neither when the button is pushed nor after it's release.
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    30 Comments
    i would like to do something similar, thqt will light up the key hole on my viatage car, hooked to the interior lights when the door opens,, what do you think?
    thank you! U gave me the ideal circuit 4 the parking lights of my bike! :)
    I hope it turns out well for you.
    id like to use ur simple design and integrate with my sound reactive leds however i think they are too reactive and finish as soon as the bass sound finishs instead i would like a type of pulsing effect that lasts 1-2 seconds after the sound reaction. So this easy circuit would suit well however i am guessing that i may blow up the transistor with 12 volts and close to 1.5 amps,,,,,, any advice on capable transistors? or is it not the transistor but maybe the capcitor i have no idea
    Well, any "power" transistor (i.e. 2n3055 or the TIP3055) should be able to handle the voltage and current ( see specs here ) if you don't need a lot of gain, it seems that it would work (but I haven't tried it).
    They are very handy (getting some flux helps too (a tiny bit on the braid), if you have a fairly low powered soldering pen).
    I sure do. but my dad has some flux, so I'm good on that part.
    Hello! Nice instructable indeed, but i was wondering if you could connect an array of 8X3 led's instead of one led.If it is possible the values for the pot,cap and resistor are still the same? Thank you!(I'm also a beginner)
    the transistor powers the leds...so long as the transistor was big enough. A small signal transistor is usually good for 50-80ma, so thats 4 or 5 ultra bright leds. Definitely not a huge amount.
    The array is made to run from a 9v supply
    I have been doing this for quite a few years, but this one was a starter project and wanted others to see how an LED can be made to fade, simply. I am not sure of the rating needed for your particular array, so I can't really answer, sorry.
    Well I tried it and it worked but I used a 100k pot accidentally instead of the 10k pot mentioned in the project. It has a fade out time from about ~10sec up to ~20sec.It is very nice.Thank you again!
    It might be good to put in a small resistor in series with the pot. so you don't ever give it full power on the zero setting.
    The electrical world is somewhat beyond me but I find this facinating Goodhart. Thanks for sharing. 5
    Thank you.
    Like math or sewing or any skill, it just takes a little time to learn, and as we all know, a little less time if there is an interest :-)
    Not to bore you with a lot of details, but it is funny even that I even ever got interested in electronics, since I was always deathly afraid of being shocked (I hate static shocks). :-)
    LOL I hate those too. I know about learning to sew so now I can relate, what a great way to face your fears though.
    . Nice job. . The wood grain is really distracting to my eyes. Try using a plain background. . > Since the schematic is REALLY straightforward . I have a pretty good idea what's going on, but a beginner might not.
    Ok, I have made some minor adjustments to the wording....Is this more along the lines of what you mean to help out the beginner ?
