***If you have wired up LEDs before, this explanation might seem overly simplistic. Consider yourself warned.***
Remove these ads by
Signing UpStep 1Get some LEDs
I know that there are many projects already posted that contain information about how to wire LEDs for simple projects - LED Throwies, LED Beginner Project: Part 2 and 9v LED flashlight - teh best evarrr!, but I think that there could still be some use for a detailed step by step explanation about the basics of LEDs for anyone who could use it.
The first step was to buy some supplies and figure out what I would need to experiment with. For this project I ended up going to Radioshack because its close and a lot of people have access to it - but be warned their prices are really high for this kind of stuff and there are all kinds of low cost places to buy LEDs online.
To light up an LED you need at the very minimum the LED itself and a power supply. From what I have read from other LED instructables wiring in a resistor is almost always a good idea.
If you want to learn about what these materials are check out these wikipedia entries:
LEDs
Power supply
Resistors
Materials:
LEDs - I basically just reached into the drawer at Radioshack and pulled out anything that wasn't more than $1 or $2 per LED. I got:
2760307 5mm Red LED 1.7 V
2760351 5MM Yellow LED 2.1 V
2760036 Flasher Red LED 5 V
2760041 2 Pack Red LED 2.6 V
2760086 Jumbo Red LED 2.4V
Power Supply - I really didn't know what I would need to power them so I bought some 9V batteries and some 1.5V AA's. I figured that would allow me to mix and match and make enough different voltage combinations to make something light up - or at least burn those little suckers out in a puff of smelly plastic smoke.
Resistors - Again, I wasn't too sure what I would need in terms of resistors here either. Since I got a whole bunch of different LEDs with various voltages I knew that I would need a couple different types of resistors, so I just bought a variety pack of 1/2 Watt Carbon Film Resistors (2710306).
I gathered up a soldering gun, solder, needle nose pliers, electrical pliers, some primary wire and electrical tape too since I thought they might be useful.
For my project I am going to us a 9 volt battery and have 20 LEDs and each LED has a voltage of 3.2-3.4V at 20 mA each. I want to run every LED in a parallel circuit.
How would I go about doing this? What size resistors would i need? I bought 1/4 watt resistors could i use those? or would i need to get a 1/2, 1/4, 1/8, ect.?
Also do i need to have 20 different resistors for each LED or could i just use one at the bottom of the parallel circuit?
Do I have to keep in mine about anything else? I would be using a 9 volt 1000+ mAh battery
Thank you in advance!!!
Thanks in anticipation
Prewired 12V LEDs
High quality LED, soldered to a resistor for 12V (including 12V automotive) use. Strong connections are neatly wrapped with heat shrink and attached to colour coded wire terminating in stripped tinned connections.
Technical Spec
High Power 3mm LEDs - 7000mcd
12V DC
Presoldered Resistor
20 mA
20 cm Wire Length
High Intensity - Low Power 0.36W
Simple to Use
Long Life and Energy Saving
You can do it like this:
+12 ------------------------------------------------------------------
R R
| | o o o as many as you like
led led
gnd ------------------------------------------------------------------
Concerns:
- multiply the current per LED (shown on the specs for each LED, above you say it is .020A) times the number you want (100?) = 2A. Therefore get a power supply that can provide 12V for at least 2A (more is ok). Repeat this formula if the current is different to determine the max ps current needed.
- I wouldn't group a big pile of these RIGHT TOGETHER of in a confined space. Each dissipates .36W (almost all in the resistor), so three or four tightly together (or out of air flow) will be a watt of power, and will start getting a little hot. For this issue, a much better solution would be to create your own LED 'cluster' of series LEDs and a single resistor setting the voltage. If you created 33 sets of three LEDs on the same line with a single custom resistor value to limit to 20mA, then your power dissipation would go way down. This is because the power would go toward light instead of being boiled away in the resistor - resistors just waste!
So this:
12V+ ------- led ------- led ------- led ------- resistor ------- gnd
3.2V 3.2V 3.2V 12v-9.6=2.4V
2.4V /.020A = 120ohms
2.4V x .020A = .048W
Note this dissipates lots less in the resistor. and there are only 33 resistors instead of 100. it uses the voltage much better.
But if you can easily get air to these guys, you'll be fine.
So: in your example above you have a 5V supply, and an LED that uses 20mA at 3V, then the voltage 'left over' across the resistor on any one leg is 2V. 2V/100ohms = .020A (20mA). Thus each leg would correctly function with a 100ohm resistor.
Each leg draws the 20mA as a separate subsystem, as it's own circuit. You should see it as if the + point in the drawing above were two independent batteries. The only limitation would be the maximum current available at the + point... remember that mA are thousandths of Amps, so a power supply rated 1A @ 5V would provide enough power for 50 LEDs... 50 x .020A (20mA) = 1A... batteries can do much better than 1A without much voltage reduction.
I hope this helps you think about this in a way that allows you work with LEDs and resistors in the future. Please reply with any questions or comments.
Sorry I wasn't clear. I was referring to step 8 where he used the 9V and wired the two LEDs in parallel.
R = (9V - 1.7V) / .04A
R = 182.5 Ohms
So in that case it would be a 200ohm resistor for each correct?
My problem is that the middle row of Leds always gets burnt out.
The first time I didnt use any resistors and the middle row completely burnt out but the rest were fine.
Second time, I only had 470ohms 1/4W resistors. Same issue - the middle row burnt out.
Also, i only have 470ohms resistors, if i used the right amount (100 ohms ) would this solve my problem?
Why the middle row "burns up" ? One or more of your LED's is faulty ( "open" or of a different type ) or the resistor in that row can't handle the power ( too small in watts such as 1/8 or 1/16th of a watt value ( also "opened" - look for the new all dark brown colour band )) AND -- If you try to reuse an LED that you already burnt up, It may continue to act as a "open" in the redesigned circuit. Test each LED with a 1.5 v battery before reuse. I use a 9 volt battery with a 220 resistor in series to test all my LEDs.
Finally , 470 ohms should work just fine. ( see note above about using "open" LEDs)
Thanks
Don't go to an online calculator, you should learn it as it is simpler and more effective than an online source.
V=IR (Voltage = Current times Resistance)
if the supply voltage is 5 the forward voltage is 2.5 and the forward current is 25 mA or .025 amps.
R=V/I so R= (5-2.5)/.025 so R=2.5/.025 which is 100 ohms. It is simple to use and more effective than an online calculator. There is a good site that explains this:
http://cuttingedgescienceclub.blogspot.com/2012/01/ohms-law-practice-problems.html
scroll down to the section labeled LED problems or you can look at the earlier sections to help.
Always figure out the forward voltage (how many volts it eats up/needs to run) the forward current (the optimal amount of current that it wants) and the voltage supply you have.
12v (power) - 1.5v (LED voltage) = 10.5 too much voltage.
If the LED runs at 20ma... then 10.5v / 0.020 = 525 ohms... or about 560 ohms. (Standard resistor value.)
But most LEDs I have seen use 2.2 to 3.4 volts... so run the math with those numbers.
Thank you for the reply tho. i am new to the whole LED thing, and i am currently working on a 4 LED USB tester that involves bi-directional current...basically it tests for proper polarity, as well as proper wiring (ie data NOT hooked to power, and power not hooked to data as well as wether or not both are wires backwards). i just finished soldering it together, but none of the led's are working...i know its in the way i designed it somehow...
http://www.ledtronics.com/html/ColorChart.htm
You can also hold down the ALT key and type the decimal value of the character but wasn't successful getting the character to print out. My guess is it has something to do with the character map I was using. In any case, I think using charmap is probably the best way to print non-keyboard generated character.
My smaller array is fed by a 12vdc 150mA power supply using 20 LED's hooked in parallel. they hooked up using 510 ohm resistors.
I had 4 burn out while handling the unit. was this because of something I did wrong?
Im building tail lights for a custom car. so they will be fed by the cars 12 volt system.
Any help?
