LEDs for Beginners
Step 2The LED
The LED
LEDs come in different sizes, brightnesses, voltages, colors and beam patterns, but the selection at Radioshack is pretty small and so I just picked up a couple different LEDs from what they had in a few different brightnesses and voltages. I kept close track of what LED was what voltage because I didn't want to accidentally send too much current through one of the low voltage LEDs.
The first thing I did with the LEDs was figure out which wire (its called an electrode) was positive and which was negative. Generally speaking the longer wire is the positive electrode and the shorter wire is the negative electrode.
You can also take a look inside the LED itself and see whats going on. The smaller of the metal pieces inside the LED connects to the positive electrode and the bigger one is the negative electrode (see picture below). But be warned - in the LEDs I picked up I didn't always find this to be true and some of the LEDs had the longer electrode on the negative when it should be on the positive. Go figure - its OK though, if it didn't light up I just flipped it around.
Once I knew what was positive and what was negative I just had to remember what the voltage of each LED was.
All my LEDs recommended 20mA of current. 20mA is standard for most LEDs.
9 comments
Dec 29, 2006. 8:14 PMmikeybee says:
Here's another, pretty sure fire way to tell which side is (+) or (-): Most LEDs come with a very small raised ridge at the base of the 'bulb'. If you look closely at that ridge, it's not a complete circle -- there will be a small notche-off portion. This notch-off, from what I've found so far, is always lined up with the (-) side of the LED.
May 21, 2010. 1:10 PMblainewood says:
This is by far the best way to distinguish which lead is an anode and which is a cathode.
Apr 1, 2010. 3:53 AMzombiefire says:
mine are the same size HELP!!!!!!!
Feb 10, 2010. 9:15 PMpeepee4 says:
i need leds!
Jan 1, 2009. 3:33 PMfreerunnin1 says:
the flat side on the bottom ring of an LED is the negative:)
Jan 3, 2009. 9:56 AMLa Tour Rouge says:
is that the one called an anode?
Jan 5, 2009. 2:51 PMEirinn says:
The anode is the positive, at least according to the image tip posted a couple of inches over your comment on the first picture on the page :)
Mar 26, 2007. 1:57 PMchadd_from_pa says:
The longer lead is not always the positive (anode). Some LEDs are backwards (such as many infrared LEDs), where the short lead is the anode and the long lead is the cathode. This site has more info about designing simple LED circuits and they also offer tech support via phone or email: http://www.LunarAccents.com
Feb 24, 2007. 8:16 AMdowngrade says:
Also, on almost all LEDs the leads will be differnt lengths, The longer one should be the positive.
Feb 9, 2007. 3:27 PMThierryElec says:
On 660nm "deep red" LEDs, the reflecting cup (and also the bottom of the LED die) is the anode : this is the exception to the general rule. Sorry, I first posted this comment on the "view all steps" page the first time.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
814
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
