LEDs for Beginners
Step 3Power supply
Power supply
To make the power supplies I just soldered some wire onto the ends of the batteries I had bought so that I could easily attach the LEDs to them. The 9V battery served as my 9V power supply, one AA battery made a 1.5V power supply and three AA batteries bundled together made a 4.5V (1.5V + 1.5V + 1.5V = 4.5V) power supply. I didn't use alligator clips on the ends of the wire, but they would have been helpful here.
16 comments
Jan 18, 2011. 1:37 PMkawaii kappuke-ki says:
Could you use button batteries? I want to use the LED's on clothing and those big batteries are to bulky.
Jan 22, 2011. 9:35 AMMunchys says:
I think they have a thing called lilypad for clothing and you can use thread thats conductive look at sparkfun.com they have it also you would probably want to use smaller leds maybe SMD.
And you can use any kind of batteries
Jul 19, 2010. 1:51 PMgeekman101 says:
for te 9v battery you can just use a 9v battery clip which connects to the two terminals and has 2 wires coming off it. ;^)
Jul 18, 2010. 12:55 PMnax says:
What about using one of those wall plug things that come with so many electric things? They usually have the voltage and amps stamped on them someplace.
Jan 4, 2010. 7:55 PMbatman2000 says:
I fly electric model airplanes and have soldered up many battery packs.  The secret is to tin the battery terminal first then solder the wire to it.  You should use at the very least a 30 watt iron to get the heat to the terminal as quick as possible so that you don't heat the battery too much.  It is important not to get the battery hot as this may ruin the battery and could even lead to thermal runaway and possibly an explosion.
Oct 20, 2009. 9:14 PMRileymi323 says:
or solder the wire to a piece of aluminum and then tape tht to the ends of the batteries??
Dec 1, 2009. 3:01 PMverence says:
Solder anything to a piece of aluminium?!? If you know how to do that, please tell me!
In normal atmosphere, aluminium coats itself with a (very thin) layer of aluminium oxide. Which can't be soldered with anything I know about. It might be possible in a nitrogen atmosphere with very powerful (reducing) flux.
With aluminium, IMHO crimping is the way to go. But with LEDs I would just use the good old copper wires.
Dec 8, 2009. 9:58 AMMOWMIKE says:
Aluminum can be soldered with products made for that purpose; not practical to buy  a $20+ pack of AL rods unless you're going to do a lot of work with the material.
Oct 24, 2009. 9:29 PMwhunt says:
Good idea Riley, thanks for turning me on to this site, your phlebotomist, Bill
Mar 11, 2007. 8:35 PMs600cam says:
Never solder anything to a battery. Instead, use a battery pack and place the batteries into that. Soldering to a battery can/will make it explode, and battery acid will get everywhere.
Dec 7, 2009. 7:16 AMpfred2 says:
As far as never goes;
I have soldered directly to both dry, and wet cell batteries and have never had an explosion issue. Then again I *do* know how to solder!
Dec 2, 2009. 10:42 AMMinifig666 says:
 Most batteries these days have a more powdery substance in them. Although I still would not recommend it.
Jan 20, 2010. 11:02 PMwwejason says:
Lookup the MSDS for Energizer alkaline batteries which recommends not soldering anything to the battery because the solder can cover the vent holes which keep them from exploding in the event of extreme heat or general failure. Ever leave a battery in a device for a long time and come back to find it corroded, yet no evidence that the battery exploded? That's because the catalyst can ooze through the vent holes rather than building up pressure.  "Batteries normally evolve hydrogen which, when combined with oxygen from the air, can produce a combustible or explosive mixture unless vented. If such a mixture is present, short circuits, high temperature, or static sparks can cause an ignition."    http://www.officedepot.com/pdf/msds/696526.pdf
Jun 24, 2009. 4:01 PMMikyVengeance says:
what does a battery pack look like? any links? thanks : D
Sep 4, 2009. 10:19 PMCynda2 says:
where do you get the wire?
May 30, 2009. 7:04 AMarvinx5 says:
so you mean the black is the positive and the red is the negative
Mar 26, 2007. 2:01 PMchadd_from_pa says:
You can also try an AC to DC power supply such as a wall mount transformer or house plug. Be sure to use a voltage regulated power supply or the voltage will be higher than required if your circuit does not draw the specified current. This page has lots more info on basic LED circuits: http://www.lunaraccents.com/nav-educational-LED-information.html
Mar 24, 2007. 11:19 PMUnforgiven_God says:
uh, i dont really know a lot at all about this stuff...can you just use electrical tape and tape the wires to batteries?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
814
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
