LEDs for Beginners
Step 8Wiring up multiple LEDs in parallel
Unlike LEDs that are wired in series, LEDs wired in parallel use one wire to connect all the positive electrodes of the LEDs your using to the positive wire of the power supply and use another wire to connect all the negative electrodes of the LEDs your using to the negative wire of the power supply. Wiring things in parallel has some distinct advantages over wiring things in series.
If you wire a whole bunch of LEDs in parallel rather than dividing the power supplied to them between them, they all share it. So, a 12V battery wired to four 3V LEDs in series would distribute 3V to each of the LEDs. But that same 12V battery wired to four 3V LEDs in parallel would deliver the full 12V to each LED - enough to burn out the LEDs for sure!
Wiring LEDs in parallel allows many LEDs to share just one low voltage power supply. We could take those same four 3V LEDs and wire them in parallel to a smaller power supply, say two AA batteries putting out a total of 3V and each of the LEDs would get the 3V they need.
In short, wiring in series divides the total power supply between the LEDs. Wiring them in parallel means that each LED will receive the total voltage that the power supply is outputting.
And finally, just some warnings...wiring in parallel drains your power supply faster than wiring things in series because they end up drawing more current from the power supply. It also only works if all the LEDs you are using have exactly the same power specifications. Do NOT mix and match different types/colors of LEDs when wiring in parallel.
OK, now onto to actually doing the thing.
I decided to do two different parallel setups.
The first one I tried was as simple as it could be - just two 1.7V LEDs wired in parallel to a single 1.5V AA battery. I connected the two positive electrodes on the LEDs to the positive wire coming from the battery and connected the two negative electrodes on the LEDs to the negative wire coming from the battery. The 1.7V LEDs didn't require a resistor because the 1.5V coming from the battery was enough to light the LED, but not more than the LEDs voltage - so there was no risk of burning it out. (This set up is not pictured)
Both of the 1.7V LEDs were lit by the 1.5V power supply, but remember, the were drawing more current from the battery and would thus make the battery drain faster. If there were more LEDs connected to the battery, they would draw even more current from the battery and drain it even faster.
For the second setup, I decided to put everything I had learned together and wire the two LEDs in parallel to my 9V power supply - certainly too much juice for the LEDs alone so I would have to use a resistor for sure.
To figure out what value I should use I went back to the trusty formula - but since they were wired in parallel there is a slight change to the formula when it comes to the current - I.
R = (V1 - V2) / I
where:
V1 = supply voltage
V2 = LED voltage
I = LED current (we had been using 20 mA in our other calculations but since wiring LEDs in parallel draws more current I had to multiply the current that one LED draws by the total number of LEDs I was using. 20 mA x 2 = 40 mA, or .04A.
And my values for the formula this time were:
R = (9V - 1.7V) / .04A
R = 182.5 Ohms
Again, since the variety pack didn't come with that exact value resistor I attempted to use the two 100 Ohm resistors bundled together in series to make 200 Ohms of resistance. I ended up just repeating the mistake that I made in the last step again though, and wired them together in parallel by mistake and so the two 100 Ohm resistors only ended up providing 50 Ohms of resistance. Again, these LEDs were particularly forgiving of my mistake - and now I have learned a valuable lesson about wiring resistors in series and in parallel.
One last note about wiring LEDs in parallel - while I put my resistor in front of both LEDs it is recommended that you put a resistor in front of each LED. This is the safer better way to wire LEDs in parallel with resistors - and also ensures that you don't make the mistake that I did accidentally.
The 1.7V LEDs connected to the 9V battery lit up - and my small adventure into LED land was completed.
13 comments
Jul 19, 2010. 4:52 AMarduinoer says:
If you wired a car battery to any amount to leds, it would burn it out. I car battery has hundreds of amps. Leds take .08 amps
Jul 20, 2010. 6:59 AMyour_dragon113 says:
I'm sorry but you're wrong. It's the Voltage that'll kill the LED. It will ONLY take the Amps that it needs. If you take a car stereo and hook it up to a 1 Amp power supply then, by your way of thinking, it shouldn't work. It won't work at full volume but it Will work up to 1/4 volume quite nicely. The unit needs 12VDC and about 4 Amps to run at peak performance. 12 is the key. Otherwise when you hook it up in the car it'd blow up due to the "hundreds of amps". The LED is rated for a typical VOLTAGE. It will ONLY draw the current that it NEEDS...no more. I suggest doing some more research and test your views prior to posting. Voltage says what you can run...Amps tell you how Many and how Long you can run it/them.
Oct 12, 2011. 7:03 PMJohn_Roan says:
lol, pretty much everything you just said is completely wrong. I think you should do some more research yourself, before misleading others.
Mar 25, 2011. 11:07 AMcolin55 says:
It's actually the CURRENT that will kill the LED as the current provides the heating-effect that will destroy the crystal.
As soon as you supply a voltage higher than the CHARACTERISTIC VOLTAGE of the LED (about 1.7v for a red LED) the LED will want to take a very high current and it is this CURRENT that will over-heat the LED.
See 30 LED Projects on Talking Electronics website:
http://www.talkingelectronics.com/
http://www.talkingelectronics.com/projects/30%20LED%20Projects/30%20LED%20Projects.html
Colin Mitchell
Mar 10, 2007. 1:23 PMbabylonfive says:
The two big reasons why you place a resistor in series with each LED are: - safety - so that if one LED burns out (becomes an open) the remaining LED would use twice the current (overcurrent) and then fail as well - so that the current and brightness will be somewhat equalized Imagine a situation with two LEDs of the same type but a sightly different forward voltage at the specific current - or think of it really as a curve of current over forward voltage. Then, because one LED uses more current for the same forward voltage, it's brighter... sometimes by a lot. Finally, when the battery voltage falls, the higher forward voltage LED winks out. David
Apr 9, 2009. 10:09 AMjustaj says:
So if you add a resistor in series with each LED, does the resistor have to be the full value? So for example he used two 100ohm resistors in series above. If he did what you said, would it be a 200ohm resistor for each? My guess would be yes but I am new to this.
Apr 9, 2009. 11:29 AMbabylonfive says:
No, you would use the same working configuration for a single leg or multiple legs, up to the limit of the power supply.
So: in your example above you have a 5V supply, and an LED that uses 20mA at 3V, then the voltage 'left over' across the resistor on any one leg is 2V. 2V/100ohms = .020A (20mA). Thus each leg would correctly function with a 100ohm resistor.
Each leg draws the 20mA as a separate subsystem, as it's own circuit. You should see it as if the + point in the drawing above were two independent batteries. The only limitation would be the maximum current available at the + point... remember that mA are thousandths of Amps, so a power supply rated 1A @ 5V would provide enough power for 50 LEDs... 50 x .020A (20mA) = 1A... batteries can do much better than 1A without much voltage reduction.
I hope this helps you think about this in a way that allows you work with LEDs and resistors in the future. Please reply with any questions or comments.
Apr 9, 2009. 5:09 PMjustaj says:
Thanks for your reply!
Sorry I wasn't clear. I was referring to step 8 where he used the 9V and wired the two LEDs in parallel.
R = 182.5 Ohms
So in that case it would be a 200ohm resistor for each correct?
Apr 9, 2009. 8:08 PMbabylonfive says:
If you mean about 200 ohms (i.e. 180 ohms) on each leg, then yes. In fact, up to the limit the 9V battery will source, you can keep adding legs with an LED and a resistor; it'll keep adding current, and reducing battery life obviously. Two will use 80mA, 3 will use .12A etc.
Jul 2, 2011. 3:26 AMsfrazier2 says:
It seem you know a lot about led i'm looking to go to led on my reef aquarium to save energy and money I have now metal halide total 500 watts. the heat is crazy hot and the light bill is through the roof, what would you recommend for a 60"x10" strip
Apr 9, 2009. 11:34 AMbabylonfive says:
One extra correction I just noticed in my original answer: If two LEDs are wired in parallel and use a single resistor, that CAN work if the resistor is sized for the combined LEDs desired current, and if the voltage drop is very close to each other (i.e. they come from the same lot of material)... this is not a horrible thing to do, and could work... it just usually doesn't work terribly well, because LEDs can easily have different drops and the orginal comment still holds... I just realized I sounded like "it won't work"... and really... it will work for a while.
Jul 14, 2010. 12:29 PMEntropy512 says:
However, strongly not recommended, since, as stated above, if one LED fails the others will be overdriven, so multiple parallel strands without per-strand overcurrent protection will result in a cascading failure.
Apr 4, 2010. 5:39 PMbananashake says:
I am wiring six 2.1V led's with 25mA each in parallel to a 11.5V power source. I am going to put a resistor on the positive leg of each individual led. What formula should I use to determine how many Ohms of resistance I need to put on each resistor of each led in this situation? Should I use (11.5-2.1) * .150=62.66 Ohms or should I find out how much resistance one 2.1V led with 25mA would use with a 11.5V power source? Ex. (11.5-2.1) * 25 ? I really don't know which formula to use, please someone help me find the answer to this question. I'm only 16 years old and I'm new to this kind of electronic stuff.
Apr 11, 2010. 6:33 AMkrisavi says:
 Hey, it should be the right formula tho you may want to recheck at ledcalc.com/ under parallel connection part...
Dec 10, 2009. 7:44 AMTitus_Taber says:
 Just to clarify, your parallel resistance formula is a little off. For n resistors in parallel it should be 1/Req=1/R1+1/R2....+1/Rn
However just for two resistors you can do (R1 x R2)/(R1 + R2) which is why your 100/2 = 50 worked in the previous step.
May 29, 2008. 7:22 PMoil4121 says:
Thanks, this does help me alot.
Jan 23, 2007. 12:18 AMxenobiologista says:
Thanks for the explanation with concrete examples. For some reason electronics is the one part of physics I always had problems with.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
813
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
