Materials
1 SPST toggle switch
3 LED lights - 1 green, 1 red, and 1 white
25" of black wire (or 5 pieces of 5")
25" of red wire (or 5 pieces of 5")
1 1K � resistor (brown-black-red-gold)
Butyl rubber tape (a.k.a. monkey dung)
1 zip tie
Tools
Soldering iron and solder
Vice or clamp
Wire cutter
Wire stripper
Red marker
Small screwdriver
1/4" drill bit and drill
Remove these ads by
Signing UpStep 1Part I: Attaching the LED lights to your Sea Perch (Steps 1 - 4)
(2. Strip about 1/4" of insulation from each end of each piece. Twist the inner wires (strands) on each end to prevent fraying and breaking.
(3. On each of the LEDs, find the positive leg and label it with red marker. Typically, it is marked by a longer leg. Otherwise, you can use a 2 AA batteries (3V) to test for the polarity of the LED. Do not connect the LED to the 12V battery used to power your Sea Perch or the LED bulbs will burn out.(
4. Solder one piece of red wire to the positive leg of each LED, as shown in diagram 1. You should solder as close to the bulb as possible (without touching or burning the bulb). Similarly attach a piece of black wire to the negative leg of each LED. Cut off the lower portion of the LED legs that are unnecessary. Do this for all three of the LED lights.
haha, i do believe we've met when i was interning last summer.
let me know if there's anything else I can do to help out...
If you have some of the materials and the tools lying around, you will be able to save lots of money. Have fun!
