3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
The Most Basic LEGO 9V Flashlight.
There are lots of 9V flashlights instructables. Mine only takes advantage of the perfect fit of 5mm LEDs in the holes of the pieces of the classic brick of LEGO and the fine and "I paid for it" look of the brick.
Also thanks for the ones explaining how to reuse the connectors of exhausted 9V batteries.
Thanks for your time!
Step 1Elements:
Elements:
You need:
1  2x4 plain brick of LEGO
1  2x4 "normal" brick of LEGO
3  5mm 3V LEDs
1 Connector of an exhausted 9V Battery
You may (will) need a solder an lead.
Of course you need also a working 9V Battery...
14 comments
May 27, 2012. 2:11 AMjjone538 says:
Great! This is Awesome We need more cool lego projects like this
May 23, 2012. 12:56 PMskolsox says:
Even simpler than that, many legos come predrilled with those three holes, and 9volt leads are cheap at radioshack, great instructable though
May 23, 2011. 6:32 PMsplazem says:
Sweet! You should put legos around the battery.
Feb 18, 2012. 12:07 AMCatsunami says:
Thats what I was thinking as well. You could assemble a whole flashlight out of legos - easy to open up and pretty cool. Im going to try this when Im back home :D
Aug 4, 2011. 7:17 PMKwartzKitten says:
What a cute idea! And totally useful too, I mean do you know how easy it is to get your hands on a 9v and how long leds last--- no wait you probably do but still.
Jul 24, 2011. 8:37 PMchipper35 says:
While the language could use a little touching up in places, this is an excellent instructable!!
Sep 10, 2011. 7:59 AMpbergeronronronron says:
leds use 1,7 volts, x3 = 5.1 v , you should put a small resistor of around 160ohms in series with your circuit just so a full battery dont kill your leds
Jun 21, 2011. 12:22 PMchuckr44 says:
I'll be darned. The wikipedia page above was modifed just yesterday. Red LEDs really did come down to 1.7vdc.
Jun 21, 2011. 12:15 PMchuckr44 says:
4 years ago I made LED flashlights. Red LEDs took 3vdc, super bright white LEDs needed 5vdc each. Has this changed?
That is why my first projects were to convert 2 cell (3v) regular flashlights into a single red LED, no resistors needed, just simple wiring and stuff that LED into the screw in bulb base.
Jun 20, 2011. 10:31 PMFinderzkeeperz says:
My kids will totally get a kick out of this.
May 24, 2011. 7:22 AMmischka says:
Simple and nice. I like it
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
25
Author:infob
