Introduction: LEGO Concession Stand
What you will need:
1 - 4x4 piece (flat)
2 - 1x4 pieces
2 - 2x4 pieces
4 - 2x6 pieces
10 - 1x6 pieces
Note: Any piece can be substituted by a combination of smaller pieces adding up to the original size.
Estimated Build Time: 5-10 minutes
Step 1: Step 1: Construct First Sidewall
Attach five 1x6 blocks one on top of another so that they form a wall. Next, attach one 1x4 block to the bottom. Align the 1x4 block so that one end is flush with the edge of the 1x6 blocks.
Step 2: Step 2: Construct Second Sidewall
Repeat step 1, so that you have two identical sidewalls.
Step 3: Step 3: Construct Front Wall
Stack two 2x4 blocks on top of each other. Next, attach one 2x6 block to the bottom of the 2x4 blocks. Align the 2x4 blocks in the center of the 2x6 block so that there is a 1x2 section left on both sides.
Step 4: Step 4: Insert Counter Top
Place a flat 4x4 piece on top of the 2x4 piece on the previously constructed front wall. Center the counter top so that there is a 1x4 section overhanging both sides of the 2x4 block.
Step 5: Step 5: Attach Walls
Attach the overhanging 1x2 section of one of the sidewall sections to an empty 1x2 section of the front counter section. Attach the other sidewall on the other side of the front counter in the same manner.
Step 6: Step 6: Attach Roof
Attach each 2x6 piece so that one end of the block connects to each sidewall. Place each 2x6 block side by side so that all sides of the roof are flush with the sides of the concession stand.
