3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LEGO LED LIGHT (mini flashlight, led light)
This instructable will show you how to make a cool and very useful mini LED flash light that will prove very useful.
I don't know if this has been made before. I decided to make one because I wanted to make something myself because I find it gives me a sense of achievement.
I was motivated to make this because I hate not being able to find the key hole for my car, this is not only annoying but you can accidentally scratch the paint on your car. (I don't have central locking)
Step 1Things you will need / Ingredients / Materials
Materials:
> 5mm LED (colour of your choice)
> Small 4x2 LEGO brick (colour of your choice)
> Switch or momentary on switch (I used one of the small square ones because they are easily found and easy to use)
> Small gauge wire
> Soldering iron and solder
> Hot glue gun and glue sticks
> A key ring (I didn't use a key ring but used some thick electrical wire)
> 3 mini cells (I got mine from a A23 battery)
http://www.instructables.com/id/12-Volt-Battery-Hack!-You_ll-be-Surprised.../
> Some way to hold the cells (see pictures)
> Dremmel (Not necessary but useful)
13 comments
Dec 22, 2009. 10:40 AMD5quar3 says:
 how do you put the 2x4 brick on the bottom did you glue it?
Dec 24, 2009. 5:08 PMD5quar3 says:
 thanks i built it today
Oct 1, 2009. 2:29 PMLotsafish says:
Very nice, I assume you used a 2x4 lego brick for the underside, my question is do you cut off the circular on th top of it before glueing it on or not - or does it not matter?
Aug 5, 2009. 1:19 PMHeywasup says:
how do u hollow the inside of the lego?
Jul 12, 2009. 8:01 AMcress says:
Would it be possible to put the switch inside the lego brick and just have the actual circular button poking out?
Jul 21, 2009. 4:14 PMcress says:
Aaa ye cool I may just leave it on the outside then...also how do you wire up the switch...I have one like yours with 4 contacts...do all 4 have to be wired together?
Jun 25, 2009. 2:19 PMpatapon says:
good luck!
Jun 24, 2009. 7:08 AMTXTCLA55 says:
nice ible, I remember trying to make one like this when I was young; however I only got as far as getting a light bulb!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Davidnipp
