3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LEGO Nikon IR Remote
(You can skip the paragraph)
My sister has a Nikon D60 camera and is an active photographer. She had been begging for a remote control for the camera and this particular model doesn't have the option of wired remote, which would have been easier to make myself. The original ML-L3 remote costs something around 40$ in my local photo equipment shop. So I browsed the web a bit and found out that someone had recorded the remote signal and built a diy-version of the remote. I said to myself: "I can do that!" And so I did. The thing cost me some 7$, not counting the cost of the PCB  and time.
!!! This is by any means NOT my original idea. The construction and code written, however, is. If anyone feels offended by not being properly credited then let me know. !!!
The following instructable assumes that you have the equipment and skills to :
- Manufacture a PCB
- Program a microcontroller (in my case a PIC)
- Chop up/hollow out a LEGO brick
- Test the final product (you'll need a compatible camera or a friend with one)
Step 1Parts list
Parts list
The following parts will be needed:
- PIC12F509
- 5mm IR LED
- Momentary push-button
- Resistors of 100R and 100K, each 1/8W to save space
- Current limiting resistor for the LED, mine was 12R for a 130mA diode. Yours might be different.
- NPN transistor, I used BC547 because I had one already
- Two small button batteries, The ones I used are called D393, 393, LR754 or AG5 depending on the manufacturer
The batteries must fit in the LEGO block along with the rest of the circuitry.
Materials and tools needed are:
- 2x6 LEGO block and two 2x3 thin blocks so that the batteries can be accessed later.
- 5mm and 3.5mm drill bits to drill the holes for the LED and button
- Neelde-nose pliers to carve out the LEGO block, I realised that using knives or a dremel is just way too complicated and simple pliers do the trick well-enough.
- A good sharp knife to persuade the block to fit the batteries
- A file to shape the PCB
- Some super-glue
- Bits of double-sided foam-tape
- All the required materials to make and solder a copper circuit board
27 comments
Nov 13, 2011. 10:56 PMaidanjarosgrilli says:
can you make one for a canon eos 400d? If you know how can you make an ible?
Sep 3, 2010. 12:53 PMDemonSpawn says:
how do you figaur out these codes if you dont know it??
Sep 3, 2010. 12:52 PMDemonSpawn says:
Any idea how i could use a arduino instead of the PIC and also what the ir code sequence for a sony alpha 200 is??
May 7, 2010. 5:45 AMlindland1 says:
is there another kind of chip or pic chip i could use
Apr 15, 2010. 1:49 PMbenseese says:
I'm sorry to rain on the parade, but I do want to point out a couple things. I take it you're outside the US, because the ML-L3's street price here is generally $17-20, and I've never heard of more than $25. Shipped from NYC, they are about $23. And maybe more relevant to this project, eBay knockoffs are $2-5 shipped worldwide. So while this is fun & cool, it's hardly a money-saver.
But the real criticism I have is your size comment. In the all-important 'thickness' dimension, the ML-L3 is 1/4 inch. Your design is more than twice this thick. I think this is the dimension that you're going to notice when you try to put it into a pocket. The ML-L3 is also slightly smaller volumetrically than yours.
Apr 15, 2010. 10:12 PMrj44319 says:
 lets not spew negative comments. It is a good build and is good starting point for people who want to learn pic's. (like me) It was also very creative in the housing area of the project. Good board each!
Apr 15, 2010. 11:14 PMbenseese says:
I'm hardly 'spewing negativity'. I simply feel that readers should not be under the false impression that they're going to save money or space. Drop those unnecessary comments from the write-up, and I'd be praising it for its cool-factor.
Apr 16, 2010. 12:08 AMrj44319 says:
 "but the real criticism" is not needed.
Apr 12, 2010. 8:27 PMnicksbrg says:
do you guys know where i can get cheap lego part?
Apr 15, 2010. 9:26 AMndinitz says:
 ebay
Apr 11, 2010. 6:46 AMch5 says:
Great!
I have done something similar with an Arduino to remote control mine but it definitively lacked that cool form factor.
Nice idea.
I also second the tv-be gone idea  ;)
I will give it a try if I find enough spare time.
Apr 5, 2010. 11:31 PMbertus52x11 says:
 Great! Would it work with a D80 as well?
Apr 6, 2010. 5:29 AMDiamond Photography says:
What about D90?
Apr 7, 2010. 6:10 AMbertus52x11 says:
Thanks!
Apr 4, 2010. 3:43 PMTesla Joe says:
NICE! I see a Lego TV-B-gone in the future!
Apr 5, 2010. 9:28 PMTesla Joe says:
I think this link may help:
http://www.ladyada.net/make/tvbgone/
Apr 5, 2010. 7:00 AMknexfan9182 says:
So, what if someone uses their T.V. remote?
Apr 4, 2010. 3:03 PMJoe Martin says:
I LOVE IT! I've got a d60 and the ML-L3 remote but it really does lack the geeky cool factor of this.
I'll be making this defiantly at some point although I may just use the dead bug technique for the circuit to save on the time needed to make the PCBs
5*
Apr 5, 2010. 6:11 AMjeff-o says:
Very cool.  I've got a cheap-o Nikon remote that I got on eBay, but I've never really been satisfied with it.  Maybe a build like this is in my future!
Apr 4, 2010. 2:54 PMkelseymh says:
Very nice project!  Reasonably well written up (a few misspellings, but what the heck), and excellent pictures of the steps.  Rated and featured.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:KoZuEst
