Introduction: LEGO Tire Headphones Organizer
Picture of LEGO Tire Headphones Organizer
An easy to make headphone/earbuds wire organizer. This is actually an idea that hit me when I saw btru's Sculpey Clay headphone cord organizer, but in this, we are going to make it out of flexible, rubber LEGO tires.
Step 1: LEGO Tires
Picture of LEGO Tires
You will need 3 LEGO tires. I found it best to use Standard-axle Large size. The small, thick ones in other words.
Step 2: Tools
Picture of Tools
Just super glue and scissors is all.
Step 3: Cut the Tires
Picture of Cut the Tires
You need to make the final product to be peanut shaped. So, cut chunks off of two of the tires so each has a little less than 3/4 circle left. Next, cut the 3rd tire into two 1/3 or 1/4 chunks. You should have these.
Step 4: Glue
Picture of Glue
Glue so the ends all fuse smoothly together and make a shape similar to this.
Step 5: It's Finished!
Picture of It's Finished!
These are two different ones that I've made as not-so-prototypes. This should fit any size of headphones unless they are full wrap around buds.
Step 6: Alternate Design
Picture of Alternate Design
If you don't want to butcher your tires, try this design. This is just two tires with holes poked through the sides, and a plastic rod in between them and in the sides. Still suggest super glue.
About This Instructable
1,364views
3favorites
License:
Bio: I may not be very active here, but I will have some projects here. Most of them will be upcycle projects. Upcyling is something that ... More »
More by blyon4:Undertale Inspired, "Butterscotch Cinnamon Pie"WWII Ration CakeInexpensive Baymax Stress Toy
Add instructable to:
