Introduction: LG 37'' LCD TV Board Swap
Step 1: Tools I Used
A skinny phillips screw driver,padded envelops,two magnets,multimeter
Step 2: Lay Tv on Flat Surface,Remove Back Panel
Lay pads down first then turn TV screen side down on them. Now remove all the screws approx. 20 of them,use magnets to fish out deep ones
Remove the stand as well
Step 3: Check for a Noticeable Problem
Look over the main board for burnt areas and for swollen capacitors... The most common problem
Step 4: Disconnect Board Wires
Pull the plugs on the main control board
Step 5: Get New Board or Capacitors....
Had a TV with the same board so I just swapped the whole board
Step 6: Put Back to Geather
Plug all your hookups back into the new or used board
Step 7: Test It Out
works great
